Tutorial[ Seagate Disks ]: Install Seagate OpenSeaChest Utilities
#41
(04-08-2019, 03:19 AM)Neo2018 Wrote: I will follow it!
(04-07-2019, 05:51 AM)tuxd3v Wrote: The fastest way is getting the disk out, and put it in your 3.5" adapter, in a Desktop or laptop,
Unfortunately, I do not have a desktop PC. And it did not work that way>
The hard drive into a USB 3.0 external enclosure 3.5 and OpenSeaChest to instal after using OpenSeaChest features to control, also did not work.
In my case I have to wait and hope that the kernel will be fixed.
Your other machine, will need to have SCSI driver there, if not you are in the same situation has you are already..
#42
(04-08-2019, 04:18 AM)tuxd3v Wrote: Your other machine, will need to have SCSI driver there, if not you are in the same situation has you are already..
Yes I understand. I have to think about how and where to do it.
Alternatively, I have to wait until the bug is fixed.
  SkiffOS server with Docker ,NAS, Home assistant, Jellyfin, Snikket XMPP (tutorial) GreyLinux 12 9,401 04-04-2022, 05:26 AM
Last Post: GreyLinux
  SimpNas server with docker - home assistant, radicale , jellyfin & esphome (tutorial) GreyLinux 0 4,328 01-17-2021, 11:33 AM
  Tutorial:How to Configure ATS Fan control tuxd3v 26 52,158 11-06-2020, 08:56 PM
Last Post: g_t_j
  Serial Connection Tutorial: FTDI 232RL hmuller 0 3,135 10-23-2020, 11:56 AM
Last Post: hmuller
Video How to Install Google PlayStore NightCrawler504 2 5,221 04-08-2020, 02:20 PM
Last Post: pino88
Wink Tutorial[ Seagate Disks ]: Optimize Life Span/Power Managment tuxd3v 14 23,541 06-19-2019, 04:40 AM
Last Post: Neo2018
Video Video and Guide to install Android to emmc no emmc to usb adapter NightCrawler504 0 3,310 04-21-2019, 07:19 PM
Last Post: NightCrawler504
  Tutorial[ Multimedia ] : Play DVD movies tuxd3v 0 2,674 02-26-2019, 07:21 PM
Last Post: tuxd3v
  Tutorial[ OpenCL ]: OpenCL 1.2 FULL_PROFILE Working tuxd3v 0 3,919 11-06-2018, 01:03 PM
Last Post: tuxd3v
  HOW TO - install linux on emmc without etcher or USB adapter dukla2000 4 10,393 07-31-2018, 12:40 PM
Last Post: dukla2000
