Pinebook Pro NVMe Question
I learned about the upcoming Pinebook Pro from an article in Forbes today: https://goo.gl/ZQUbyb
The part that really caught my attention was "an unpopulated NVMe slot."
IF someone populated the NVMe slot with a drive, would the Pinebook Pro use the built-in eMMC flash storage for startup and core OS tasks, using the NVMe drive for primary storage?
(01-31-2019, 08:27 AM)Selden Wrote: I learned about the upcoming Pinebook Pro from an article in Forbes today: https://goo.gl/ZQUbyb
To my knowledge, PCIe (which is the interface used for NVMe) isn't bootable at this time in either the BSP or mainline kernel. So, presently, NVMe drives can only be used as storage. This may however change in time.
The SD Card slot would be a viable boot device tho correct?
(01-31-2019, 12:53 PM)DennyL Wrote: The SD Card slot would be a viable boot device tho correct?
Yes, SD is bootable
Thanks, Luke, that's what I expected. I'm not interested in booting from the NVMe drive, but from the eMMC, which I assume can be partitioned, with a different distro in each partition, using GRUB at boot to select. With a 64 Gb eMMC flash storage, space might get tight, but with 128 Gb, not so much, as long as the NVMe is recognized by any of them. Plan B would be to boot from sd card, as Denny suggests. Pre-release spec isn't clear: will the Pinebook Pro have a SDHC slot or a microSD slot? Doesn't really matter, as I have a 128 Gb microSD, which can slot into a SDHC adapter.
At this point, with the Pinebook Pro not yet released, and my not having made a purchase decision, this is a hypothetical question, but I am obsessive about researching things before investing -- even for a $199 laptop.
i saw in an article that there will be 128 gb eMMC option for registered users, is that correct? in that case i could fit two and more partitions
(03-25-2019, 12:21 AM)favio Wrote: i saw in an article that there will be 128 gb eMMC option for registered users, is that correct? in that case i could fit two and more partitions
Correct.
  Pinebook Pro vs Pinetab2 Lotech 0 247 02-13-2024, 08:57 PM
Last Post: Lotech
  Maximum size of boot MicroSD for RockPro64 and Pinebook Pro commiecam 0 1,684 08-07-2022, 10:47 AM
Last Post: commiecam
  Please Help: Bricked Pinebook Pro with Keyboard Update dumbguywhobrokehiscomputer 3 3,976 07-14-2021, 02:49 PM
  Java on Manjaro ARM Pinebook Pro gulagpyromaniac 3 3,847 05-25-2021, 11:05 AM
  Setup My Pinebook 64 and Lost Password jersdayoff 5 5,798 05-01-2021, 10:29 PM
  How to boot from SD card on pinebook pro linux123 3 6,042 12-02-2020, 10:29 AM
Last Post: linux123
  Pinebook Pro- configuration aborts setting keyboard layout scroall 10 12,217 10-30-2020, 11:58 AM
Last Post: scroall
  Changing locale on Pinebook Pro Perl6_user 5 7,042 09-16-2020, 05:13 PM
Last Post: guava
Big Grin New to Pinebook Pro SanjevR 5 8,978 06-07-2020, 07:35 AM
Last Post: spikerguy
  WiFi issues Pinebook Pro sunnystormy 6 8,989 05-28-2020, 05:44 PM
Last Post: Luke
