Android 9 for Rock64?
#31
Any updates on this?
Is the Android 9.0 SDK fully uploaded?
I don't want to buy an expensive data bundle then find out it's only uploaded one third of 100GB, only shows 35.2GB.
Maybe someone can download so long and let us know if it's the full SDK?
http://files.pine64.org/os/sdk/ROCK64/RO...9.0.tar.gz
-----------------RELEASE NOTE------------------------------- ------------
[rk3328_box_pie_release_v1.1.2_20190418.xml]
Uboot & kernel:
  1.uboot: Repairing small memory may cause malloc failures;
  2.kernel:fixed PCM DSP format;
  3.kernel:dw-hdmi: Fix some scenes such as the voice assistant playing the beginning of the sound loss problem;
System:
  1. Fix boot animation package with audio.wav audio playback failure;
  2.TvSettings more settings to add performance floating window function;
  3. Fix the probability of googleplayservice crash when integrating gms;
  4. Fix the problem that the focus of the playmovie&tv part cannot be operated;
  5. Fix the video conference zoom application call without sound problem;
[rk3328_box_pie_release_v1.1.1_20190403.xml]
System:
  1. Fix the invisible problem of the mouse icon on the Amazon video playback interface (frameworks/base);
  2. Fix some machines with low probability to boot systemserver no response problem (frameworks/base);
  3. Fix some apk under infrared simulation mouse click input box will not automatically play soft keyboard problem (frameworks/native);
[rk3328_box_pie_release_v1.1.0_20190401.xml]
RKDocs&RKTools:
   1. RKDeviceTest update, support lamp configuration, etc.;
   2. Update the "RK3328 Software Development Guide Document" to the V1.3 version:
a. Add a common configuration macro description
b. Update the WideWine function configuration instructions
c. Add adjustment and save of display parameters
d. Add system debugging - Lastlog open
e. Add system debugging - serial debugging
f. Add system debugging - Log automatic save system abc.
3. Add customer common custom function patch package directory RKDocs/rk3328/PATCHES
4. Update each module's documentation to the latest version.
5. Update the programming tool to v2.65, fix the exception such as erase failure;
  6. Update tools such as KeyWrite and SecureBootTool.
Uboot:
   1. Fix 8bit logo display exception problem;
System:
  1.update aosp codes to android-9.0.0_r33;
  2.secure patch update to SPL 2019-03-05;
  3. Update hwc to version 0.56:
    a. Repair h HDMI color mode switching failure;
    b. Fix some apps to exit the splash screen;
    c. Fixing the vrefresh calculation exception causes some resolution settings to be abnormal.
    D.swith to new code branch
    e. Fix kodi playback hdr invalid problem
  4. Update settings new features:
    a. Add the application dynamic uimode whitelist function;
    b. Add the power button function menu option;
    c. Add a home page option;
    d. Repair screen saver function, fix setting screen saver setting time does not refresh abnormally;
    e. Add a boot volume protection switch option;
    f. Fix the usb option function abnormally;
    g. Fix Bluetooth Receive File option cannot open the question, etc.;
   5. Fix the boot video can not play abnormally if there is an animation package;
   6. RKDeviceTest update, support lamp configuration, etc.;
   7.omx library update, optimized 4k online play;
   8. Update the video library to the latest, fix memory leaks;
   9. Fix screencap exceptions in some scenarios
   10. Fix settings Advanced function Power button configuration user version invalid problem:
   11. Fix the problem that the network adb switch and the abc background log save switch are invalid under the user version;
   12. Fix some selinux permissions issues;
[rk3328_box_pie_release_v1.0.0_20181206.xml]
Initial release
Just a pity we will never see such Android Pie firmware since it was abandoned.
The Android 9.0 SDK for ROCK64 and ROCKPro64 already posted on PINE64 wiki site, please checked.
The Rockpro64 Android 9.0 build already posted and this one UI still maintain as 1024x600 due to match up with 7" LCD screen. We will rebuild another set in few weeks time that match up with Pinebook Pro and UI set to 1920x1080.
The ROCK64 Rooted Android TV 9.0 build also posted.
(06-13-2019, 09:48 PM)tllim Wrote: The Android 9.0 SDK for ROCK64 and ROCKPro64 already posted on PINE64 wiki site, please checked.
The ROCK64 Android TV 9.0 build still under test and looking forward on next week release. Keep my finger crossed.
yeah!!!
ROCK64 Android 9 for eMMC boot already released yesterday and this includes the Android 9.0 SDK released in PINE64 wiki site. The SD boot version hopefully able to release on this week.
The rooted version for eMMC build also posted this morning.
(06-18-2019, 11:37 PM)tllim Wrote: ROCK64 Android 9 for eMMC boot already released yesterday and this includes the Android 9.0 SDK released in PINE64 wiki site. The SD boot version hopefully able to release on this week.
Thank you for this release!
How is release ATV 9 20190617 different compared to 20190618?
I installed 20190618 on Rock64 4GB with 16GB eMMC using etcher and a USB dongle.
Below are initial observations:
 - installation and 1st boot went like a charm.
 - Screen resolution is really bad on a 55" LG OLED TV (ATV 7 worked ok on the same screen). Tried manually changing the resolution, did not really help.
 - My air mouse back button (non-rock remote) which works on ATV 7 does not work
Cheers
Any news on the SD Card release yet?
Hopefully on this week.
Is there chance to add wifi support on the upcoming release ? Thanks a lot Heart
  Rock64 Android Oreo 8.1 TV-Install adventures (Now Android 9.0) Rocklobster 5 5,101 08-04-2021, 07:35 PM
Last Post: Rocklobster
  How do I prepare/put Android on an SD card using etcher cdotsubo3000 3 5,904 06-27-2021, 02:43 PM
Last Post: clach04
  Android and SD Card gigagames 2 4,474 06-27-2021, 02:38 PM
Last Post: clach04
  Android Images (ROCK64) pineadmin 73 166,806 05-04-2021, 01:58 AM
Last Post: zet_lab
  Android 9.0 and Pluto on Rock64-1G missdeenola 1 3,943 03-12-2021, 01:38 PM
Last Post: Wizzard
  broken android microsd images jbach50 1 3,428 01-16-2021, 09:57 PM
Last Post: jimsurvak
  Android on Rock64 SD Problem ElBoluTony 3 5,884 10-07-2020, 12:10 PM
Last Post: ElBoluTony
  Error! Android Rockchip tools method BowerR64 0 2,528 09-18-2020, 08:12 PM
Last Post: BowerR64
Lightbulb Any older versions of Android for the Rock64? BowerR64 2 4,638 09-18-2020, 07:58 PM
Last Post: BowerR64
  Can't boot android 9 on rock64 maks2204 5 8,627 09-09-2020, 08:44 AM
Last Post: BowerR64
