Only ttyS2 working with rockpro64.
I am using ubuntu18 minimal LXDE image with my rockpro64.
I am using ttyS2 for UART communication. Have two doubts-
1) When i use 1500000 Buadrate, then it works fine. But when i change its baudrate to 115200 then after some time, my UART gives unexpected symbols but not correct data. So is ttyS2 should be used with 1500000 baudrate only?
2) I wanted to use ttyS4(UART4), But it is not working. Can i enable this?
Thanks.
Please update as my important task is pending on same.
Can't i use ttsS2 with different buadrate such as 115200? I am getting garbage data in this baudrate.
Thanks.
  Installing Wifi drive for the RockPro64 John45595 0 309 02-10-2024, 11:32 PM
Last Post: John45595
Wink You don't sell case and fan for "ROCKPro64 4GB Single Board Computer"? Clea 1 757 09-17-2023, 12:00 AM
  Want to check maximum toggle speed in Rockpro64 board. kundanjha 0 683 08-14-2023, 07:55 AM
Last Post: kundanjha
  Unable to boot Armbian on new RockPro64 mooseball 5 4,259 07-14-2023, 08:59 AM
Last Post: rockjonn
  Hardware fix for software sound problem on Rockpro64 Ricks Rockpro 0 891 04-06-2023, 03:59 PM
Last Post: Ricks Rockpro
  No sound on Rockpro64 with OpenWrt Patrice 1 1,326 04-06-2023, 02:46 PM
  Cant get rockpro64 working brasilikum 3 1,826 03-19-2023, 06:22 AM
Last Post: runyor
  RockPro64 Stopped working WarpLover 5 2,656 02-06-2023, 10:10 AM
Last Post: diizzy
Lightbulb ROCKPro64 + SSD case model for 3D print Spater 0 1,021 01-27-2023, 07:43 PM
Last Post: Spater
  RockPro64 and Neon rapier1 2 1,790 10-21-2022, 07:44 AM
Last Post: rapier1
