NextCloud with Rock64Pro
Question
Hello everyone,
I want to setup a NextCloud instance, and thought the Rock64Pro would be awesome.
Pardon my ignorance, yet: What would you suggest in order to connect a 4TB hdd to the board?
Should I do it via USB?
I do *not* need super sata speed.
Once the hdd/nextcloud files are synchronized, I'll be good to go with USB speed.
Would connection via USB be the ideal way?
Any other suggestions?
Thank you for your help!
(01-10-2019, 02:20 PM)aj64 Wrote: Hello everyone,
If you only want to connect a single HDD then USB 3.0 (or C) will be fine. If its a 3.5" drive you'll need to power it externally; a 2.5" HDD can be powered directly from USB 3.0.
As for installing Nextcloud, I followed these instructions on ubuntu 18.04 and have since done some minor modifications (to enable caching etc.,). I guess there are many  other ways to install Nextcloud too (e.g. docker).
[edit] moved to RockPro64 Linux subforum
Luke,
Much appreciated.
Do you know of any good fanless cases for the RockPro units?
  New LCD Display for ROCK64Pro chilicon 0 1,781 03-10-2020, 02:05 PM
Last Post: chilicon
  Rock64Pro and 4K resolution rrosenheim 1 3,167 06-16-2019, 04:53 PM
Last Post: Luke
