USB 3 type-C port Thunderbolt compatible?
I have a project I'm working on that will be using a portable Thunderbolt 3 USB type-C display (hooray for only one cable!) and was looking for an SBC that would be able to drive it. I saw that the ROCKPRO64 has a USB type-C with DisplayPort 1.2, but I wasn't sure if that means it actually supports Thunderbolt 3 or not.
It is not compatible. There would need to be a Thunderbolt controller on board and those are $95 each at the motherboard manufacturer level...
  Compatible PCIe Sata Controller spacebricker 1 1,548 02-06-2023, 10:03 AM
Last Post: diizzy
Question RockPro64 Lithium Battery Port TitleOS 0 1,869 12-05-2020, 12:35 AM
Last Post: TitleOS
  NAS mods: external serial port and power button foresto 4 6,480 10-04-2020, 11:21 PM
Last Post: zer0sig
  Cheap 4-port SATA card working with RockPro64 4Gb andyburn 6 10,645 08-10-2020, 08:36 PM
Last Post: zer0sig
  connector type SPDIF FAN RTC battery? ChriChri 4 5,640 03-21-2020, 06:47 AM
Last Post: ChriChri
  SY8113B compatible parts N.Gray 2 3,281 04-03-2019, 11:22 AM
Last Post: N.Gray
  PCIe port specifications MisterA 0 1,854 12-11-2018, 02:55 AM
Last Post: MisterA
