Does working *nix exist for Rock64?
Hey guys
Does anyone have Rock64 board with *nix 100% working?
I bought 3 boards Rock64-4G and all of them does not seem to work
One is not able to read/write eMMC (and CPU becomes very hot) - I sent it back
Two others are very unstable. I've tried ayufan's Debian Stretch, Ubuntu Bionic and DietPi
All of them crash when doing intensive I/O together with intensive CPU load. No matter eMMC or external SSD drive
I believe problem lies in poor I/O bus programming in ayufan's code
Please let me know if anyone have completely working board
(12-28-2018, 06:11 AM)brox Wrote: Hey guys
I setup a rock64 with 4G of ram as a weather station using debian stretch on 0.5.15 kernel/build with 343days of uptime. I used heat sinks to reduce throttling as I turn webcam images into time lapse video every 30 minutes and that uses all cores during processing. It would be nice to have h264 hardware encoding working.
(12-28-2018, 06:39 PM)evilbunny Wrote: I setup a rock64 with 4G of ram as a weather station using debian stretch on 0.5.15 kernel/build with 343days of uptime. I used heat sinks to reduce throttling as I turn webcam images into time lapse video every 30 minutes and that uses all cores during processing. It would be nice to have h264 hardware encoding working.
Thanks, I have case with heatsink embedded, so this should not be a problem. Will try 0.5.15
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 152 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,367 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 338 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 616 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 + Klipper + KlipperScreen Instructions godzilla62 0 610 10-22-2023, 01:52 AM
Last Post: godzilla62
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,397 10-12-2023, 05:14 PM
Last Post: tpaul
  slarm64 (unofficial slackware) Rock64 RK3328 (aarch64) mara 133 190,619 10-09-2023, 03:31 AM
  arch rock64 does not boot nemnob 0 592 07-09-2023, 03:28 AM
Last Post: nemnob
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 652 05-27-2023, 06:11 AM
Last Post: Transportsicherung
  DietPi OS for ROCK64 MichaIng 41 33,428 12-07-2022, 08:22 PM
Last Post: luminosity7
