Download RetroPie for your Rock64
Just committed this today:
https://github.com/MattAndrzejczuk/Retro...K64-PINE64
This git repo is essentially a vast sh script that tells your Ubuntu OS which packages are needed to be installed in order to get all the top emulators out there i.e. Sega Genesis, SNES, N64 etc... fully running on your ARM device.
This setup script is expecting you to already be running Ubuntu 16 or later.
Once the installer finished, start playing games by entering:
$ emulationstation
Just noticed last week there's not that much info on Rock64 and emulation so hopefully this helps everybody hit the ground running.
is it meant for amrhf ? - as an example, in N64 you wont get a dynamic recompiler working using arm64
(12-26-2018, 07:33 AM)CiniCraft Wrote: Just committed this today:
$ emulationstation
Hey there, I ran the script and asked to do a basic install. Got this after some hours:
Could not install packages: devscripts, debhelper, dh-autoreconf mali-fbdev.
I also got similar error messages when running the script. Has anyone found a way to get this working?
https://imgur.com/a/MRzh8O4
  noob with non booting rock64 4g john72carter 6 415 10-14-2020, 07:35 PM
Last Post: Rocklobster
  Python GPIO Library for the Rock64 (R64.GPIO) Leapo 34 21,682 10-13-2020, 02:35 PM
Last Post: hellonwood40
  Rock64 - boot helpmerock 2 244 10-08-2020, 01:29 PM
Last Post: helpmerock
Big Grin Rock64 as a retro-gaming console: early impressions Luke 54 38,102 10-07-2020, 11:21 AM
Last Post: jakejm79
  what is the rock64 good for? munocat 5 1,559 10-04-2020, 10:32 PM
Last Post: tomarm
  rock64, compile problems "illegal instruction", "memory fault" -> ddr_333Mhz? hunderteins 9 1,938 10-04-2020, 10:16 PM
Last Post: tomarm
Thumbs Up General firmware section for the Rock64? BowerR64 5 589 09-29-2020, 04:00 PM
Last Post: theophile
  Rock64 No Audio - Solved wbecks 10 10,677 09-05-2020, 02:32 PM
Last Post: WarpLover
  pin connector on rock64 jeanmichel 0 311 08-22-2020, 10:04 AM
Last Post: jeanmichel
  Rock64 random freezes BTB 6 1,918 08-19-2020, 05:59 AM
Last Post: wilsonYan
