Install Gapps a guide for dummys/Noobs???
I need some help here because I need install Gapps in my Android 8.1.0 installation but I don't understand the process, inside this thread (https://forum.pine64.org/showthread.php?tid=6684) I downloaded all needed files. The problem comes when I read:
Activate developer mode and get a root shell:
./adb device
./adb root
./adb remount
............ and so....
I don't understand nothing,
How I active developer mode? where? I suppose inside my android 8.1.0in my rockpro64 or but not sure...
After that I think that I should launch those commands but from where???? root shell? Should I connect my rockpro64 through class c cable to my windows pc and launch from cmd windows console??? so if the answers is yes, before I must have installed in my windows pc the SDK package? No???? And then????
God! without knowledge's is so difficult, every step ends in a wall!!!  Huh Huh Huh
Please, a kind soul could help me???? If so I promise create and upload here a "baby-step-guide" for people like me.
Thanks!
Hope i can help.
Developer mode activation is from "About tablet" in settings.
Click about 8 times on "build" and developer mode will show up.
Extract the zip and open CMD from it or navigate to the folder.
Connect with USB C cable.
After remount just copy paste the commands without the ./
http://prntscr.com/m7633r
http://prntscr.com/m763p4
no SDK's needed for it.
PM me if you need more help.
Hi BaBaaaH,
Thank you very much for your help.
Cheers.
Guide and video here:
https://forum.pine64.org/showthread.php?tid=7445
(05-01-2019, 12:46 PM)NightCrawler504 Wrote: Guide and video here:
Will this work for Android 9? I have installed 9 on 64GB SD, but no Gplay. If not is there one in the works? Thanks for 8.1 fix. Works great.
  Install Playstore on Android 8.1.0 Domo 14 24,490 04-16-2021, 02:13 AM
Last Post: Wizzard
  Install Playstore on Android 7.1.2 Domo 6 13,820 04-16-2021, 02:10 AM
Last Post: Wizzard
  Install Playstore on Android 9 image ddimension 18 27,460 02-13-2021, 12:52 AM
Last Post: chisteven
Lightbulb REQUEST: Guide to build Android images for SD / eMMC. duckkcud 3 5,771 04-23-2019, 05:36 PM
Last Post: NightCrawler504
