Rock64 as hypervisor ?
Dear All,
I'm using the Pine64 board since some months now to host my ownCloud and everything is working fine without any kind of issues !
As the Rock64 board seems to bring more power, I planned to use it as a virtualization board. But, I didn't found any tutorial that could help me to setup my board so far. I've read on the forum that some users managed installing Xen on the board, and other use Docker/Kubernete.
I realize that I first need to be clear with what I would like to do with this board : I have many other different boards used to achieve different tasks on my home network (multi-room audio system using MPD, home automation systems for my connected lights, connected heating systems, connected windows, garden water pumps ...), and would like definitively to use as less as possible boards ... Each board run either Debian or Ubuntu and hosts a dedicated application. I definitively would like to have only one Rock64 boards to hosts all that applications, BUT isolated the one from the other ... In case something goes wrong with one, I wouldn't have to others dead at the same time ... And because I do many tests on each systems to make them evolve sometime in "testing mode" (compiling from scratch, updating packages ...).
Any ideas to share with me ?
Many thanks in advance,
Best regards,
Jean
It works but I don’t know of any of the management frameworks with good ports to ARM. So you are sorta on your own with KVM CLI and config files. Real PITA.
The situation is better using container virtualization. With the limited memory footprint containers are probably better than traditional VMs anyway. Docker + Portainer works GREAT on the C2. Some of the networking constructs would work better with a modern kernel (4.4 or better). But as is its great.
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 134 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,329 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 323 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 595 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 + Klipper + KlipperScreen Instructions godzilla62 0 596 10-22-2023, 01:52 AM
Last Post: godzilla62
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,244 10-12-2023, 05:14 PM
Last Post: tpaul
  slarm64 (unofficial slackware) Rock64 RK3328 (aarch64) mara 133 189,527 10-09-2023, 03:31 AM
  arch rock64 does not boot nemnob 0 582 07-09-2023, 03:28 AM
Last Post: nemnob
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 633 05-27-2023, 06:11 AM
Last Post: Transportsicherung
  DietPi OS for ROCK64 MichaIng 41 32,961 12-07-2022, 08:22 PM
Last Post: luminosity7
