How to enable touchpad natural scrolling?
Two-fingered scrolling is working fine, but is there a way that I can reverse the direction (natural scrolling) in KDE Neon?
I found some options in Settings but doesn't work.
And it seems KDE neon doesn't recognised touchpad too.
xinput set-prop 8 "Evdev Scrolling Distance" -1 1 1
How to discover that:
xinput list
xinput list-props 8
Edit: FWIW, the trackpad does not present its self as a trackpad to the pinebook. It presents its self as a USB mouse and keyboard (pinch zoom is actually a control key press + scroll wheel movement).
Super tip.
I am using Manjaro (Archlinux).
Property device 8 was not the mouse and I could not find property Evdev Scrolling Distance.
However, after exploring the device as described above for me this worked to reverse the mouse scrolling direction.
Quote:xinput set-prop 7 "libinput Natural Scrolling Enabled" 1
The following worked for me:
System Settings -> Input Devices -> Touchpad -> Scrolling -> Reverse scrolling: Vertical
Operating System: Manjaro-ARM
KDE Plasma Version: 5.19.3
KDE Frameworks Version: 5.71.0
Qt Version: 5.15.0
Kernel Version: 5.7.0-3-MANJARO-ARM
OS Type: 64-bit
Processors: 6 ×
Memory: 3.7 GiB of RAM
Graphics Processor: Mali T860
.png   Touchpad_natural_scrolling.png (Size: 38.89 KB / Downloads: 448)
  Disable touchpad tap to click? colin.faulkingham 25 35,996 04-27-2020, 07:31 PM
Last Post: ab1jx
  Proof of concept script to disable the touchpad while typing daid 21 27,543 02-25-2018, 06:47 PM
Last Post: pfeerick
Sad touchpad edges scrolling kurai021 11 13,736 07-09-2017, 05:56 PM
Last Post: Luke
