Rock64 +DAC + CPU Cooler
hello,
it's possible use the cpu cooler with DAC Audio on Rock64 ?
The TOSLINK out, work with OpenMediaVault 4 ?
Thanks in advance
(11-30-2018, 08:05 AM)maxves Wrote: hello,
Thanks in advance
the small fan type heatsink can be used with DAC board with ROCK64.
TOSLink works on Volumio, not sure on OMV.
Thank you.
For volumio, was it necessary to install additional drivers?
I tried in virtualbox, OMV AMD 64bit and the audio work fine, but with a standard audio out, no DAC.
  Are HW design files available for ROCK64? irenek 3 4,752 12-11-2023, 09:31 PM
  Rock64 is unreliable after 3 years of service - power problem? ReleaseTheGeese 0 329 11-23-2023, 05:05 AM
Last Post: ReleaseTheGeese
  Rock64 PoE compatbility with Pi4 Hatt recent Single Board Computer offering from PINE kharak 1 1,060 04-26-2023, 11:38 PM
  Case for the rock64 that supports the POE hat. o1CRiMSON1o 0 619 03-21-2023, 03:48 PM
Last Post: o1CRiMSON1o
Brick Rock64 usb2.0 Power Control Floating GPIO Tutorial Files & Notes MarkHaysHarris777 6 13,213 01-15-2023, 10:36 AM
Last Post: ds00
  rock64 totally brick dakobg 2 1,733 11-07-2022, 05:45 PM
Last Post: olivercfc
  3D-Printable Button Pegs for the ROCK64 Aluminium Case CounterPillow 2 3,517 08-04-2022, 01:31 AM
Last Post: Vicky Weimann PhD
  Where can I find the ROCK64 POE HAT Zoz 2 2,611 06-08-2022, 12:44 AM
Last Post: Zoz
Smile wooden case for ROCK64 killor 13 16,499 03-04-2022, 06:56 AM
Last Post: killor
  1wire DS18b20 on Rock64? mypineme 6 7,024 09-28-2021, 03:07 PM
Last Post: TRS-80
