03-21-2020, 10:34 AM
update:
- kernel 4.4.217
slarm64 (unofficial slackware) ROCKPro64 RK3399 (aarch64)
update:
slarm64-current-aarch64-base-rootfs-20200628-4.4.230-rockpro64-build-20200711.img.zst.md5 slarm64-current-aarch64-xfce-rootfs-20200628-4.4.230-rockpro64-build-20200711.img.zst slarm64-current-aarch64-xfce-rootfs-20200628-4.4.230-rockpro64-build-20200711.img.zst.md5
10-15-2020, 03:33 AM
update:
slarm64-current-aarch64-base-rootfs-20201003-5.8.15-rockpro64-build-20201014.img.zst.md5 slarm64-current-aarch64-xfce-rootfs-20201003-5.8.15-rockpro64-build-20201014.img.zst slarm64-current-aarch64-xfce-rootfs-20201003-5.8.15-rockpro64-build-20201014.img.zst.md5
10-20-2020, 01:51 AM
I can't get this image to boot. It keeps hanging at
## Flatened Device Tree blob at 01f00000 Booting using the fdt blob at 0x1f00000 Installed on SD card with: zstdcat slarm64-current-aarch64-xfce-rootfs-20201003-5.8.15-rockpro64-build-20201014.img.zst > /dev/sdb Both images have the same result. Is there a boot parameter I need to change for this? Thanks.
10-21-2020, 10:41 AM
(10-20-2020, 01:51 AM)janv Wrote: I can't get this image to boot. It keeps hanging at I have on this image, when I turned on, I left the audio card in usb3, then the bootloader was overloaded. And the bootloader in spi is old or new from this release, try to erase the spi bootloader.
10-21-2020, 03:18 PM
That worked I appreciate your work. Do you accept donations in Bitcoin?
10-22-2020, 12:55 AM
Thanks, so far only patreon.
One of these days I will collect the image on the kernel 5.9.y.
10-23-2020, 03:19 PM
update:
slarm64-current-aarch64-base-rootfs-20201023-5.9.1-rockpro64-build-20201023.img.zst.md5 slarm64-current-aarch64-xfce-rootfs-20201023-5.9.1-rockpro64-build-20201023.img.zst slarm64-current-aarch64-xfce-rootfs-20201023-5.9.1-rockpro64-build-20201023.img.zst.md5
01-08-2021, 01:45 PM
update:
slarm64-current-aarch64-base-rockpro64-4.4.249-build-20210107.img.zst.sha256 slarm64-current-aarch64-xfce-rockpro64-4.4.249-build-20210107.img.zst slarm64-current-aarch64-xfce-rockpro64-4.4.249-build-20210107.img.zst.sha256 |
irradium (based on crux linux) RockPro64 riscv64, aarch64 | mara | 1 | 511 |
03-25-2024, 12:12 PM Last Post: mara |
RK3399 PCIe enumeration | jhadd | 0 | 280 |
01-31-2024, 08:56 AM Last Post: jhadd |
yocto for RockPro64 | Fide | 1 | 731 |
01-16-2024, 10:01 AM Last Post: Fide |
Installing Ubuntu Server on RockPro64 | deutschlmao | 2 | 2,647 |
10-29-2023, 04:43 PM Last Post: brotherj4mes |
Vanilla mainline Debian 11 (Bullseye) on the RockPro64 | Pete Tandy | 22 | 17,500 |
08-16-2023, 01:34 AM Last Post: varac |
How to enable CoreSight ETM trace on RockPro64 | shpark | 0 | 598 |
05-21-2023, 11:34 PM Last Post: shpark |
rk3399 and Visual Output Processor 2 (VOP2) | swan | 3 | 1,402 |
05-13-2023, 12:01 AM Last Post: swan |
Rockpro64 Dead on arrival? | quixoticgeek | 1 | 964 |
03-12-2023, 06:55 PM Last Post: quixoticgeek |
RockPro64 boot questions | misterc | 3 | 1,599 |
01-13-2023, 06:21 PM Last Post: misterc |
A fix for Bluetooth audio stuttering on the RockPro64 | raph | 2 | 1,678 |
01-03-2023, 06:53 PM Last Post: raph |
