slarm64 (unofficial slackware) ROCKPro64 RK3399 (aarch64)
hdmi sound check is not possible.
a problem was noticed, when compiling firefox, errors appeared in the dmesg followed by segfaults
[34014.908263] Unable to handle kernel paging request at virtual address fffffffffffffffb
[34014.908266] pgd = ffffffc0e550c000
[34014.908272] [fffffffffffffffb] *pgd=00000000e88e4003, *pud=00000000e88e4003, *pmd=0000000000000000
[34014.908278] Internal error: Oops: 96000005 [#9] SMP
[34014.908294] Modules linked in: af_packet 8021q garp mrp stp llc bcmdhd
[34014.908300] CPU: 2 PID: 21895 Comm: cc1plus Tainted: G      D         4.4.166+ #1
[34014.908301] Hardware name: Pine64 RockPro64 (DT)
[34014.908304] task: ffffffc0ee764600 task.stack: ffffffc0e8bac000
[34014.908314] PC is at __d_lookup_rcu+0x84/0x164
[34014.908319] LR is at lookup_fast+0x4c/0x28c
[34014.908321] pc : [<ffffff800820a000>] lr : [<ffffff80081ff5f0>] pstate: 20000145
[34014.908323] sp : ffffffc0e8bafb80
[34014.908327] x29: ffffffc0e8bafb80 x28: ffffffffffffffff
[34014.908330] x27: 0000000000000010 x26: ffffffc0f17d1041
[34014.908333] x25: 0000000094269674 x24: ffffffc0e8bafd60
[34014.908336] x23: ffffffc0d5e5f360 x22: 0000001094269674
[34014.908340] x21: fffffffffffffff7 x20: ffffffc0e8bafc3c
[34014.908343] x19: ffffffffffffffff x18: 000000000000003f
[34014.908346] x17: 0000007f82be8108 x16: ffffff80081f2ba0
[34014.908350] x15: 0000000000000001 x14: 0000000000000010
[34014.908353] x13: 00682e7373616c63 x12: 5f656b616d5f6370
[34014.908356] x11: 0000000000000023 x10: 0101010101010101
[34014.908359] x9 : 0000000000000000 x8 : ffffffc0e4ca97b8
[34014.908362] x7 : 0000000000000000 x6 : 000000000000003f
[34014.908366] x5 : ffffffc0d5e5f398 x4 : 0000000000000010
[34014.908369] x3 : 0000000000000013 x2 : 0000000000000004
[34014.908372] x1 : ffffffc0f3600000 x0 : ffffffc0f21f41b0
wicd
nm-applet , and or conman might be a plus....
anyrate getting wifi up , setting a fake ip on eth0:1  for ssh between laptop etc a plus..  to bake into image
chroot to gentoo on emmc get that baked..  & bootable
i have the raw packs from linux from scratch.. wicd pretty dead low on requiremnts list....
any rate trying to get unit headless and or using the LCD..
(01-23-2019, 02:21 PM)necrose99 Wrote: wicd
I will add the following packages for network resolution
n/NetworkManager
xap/network-manager-applet
I also leave a link to the network configuration documentation
n/NetworkManager
https://isshoni.org/pi64pie/ gentoo bins..
https://www.dropbox.com/sh/gfsfqv3p4lvnz...kP8ia?dl=0
My own generic /rpi rock64 bins made on chroot.. at scaleway.
https://github.com/zoobab/quickunpkg
Slpits gentoo tarballs.. as metadata is at end some tools ie 7zip on windows or engranpa gripe.. while others ignore.
Python /gCC longenoug to build up a few tools on slackware host
Ie gcc for slackware and etc.
Wicd. Pygtk , and a python.. setup.py... wala.
(Our land lord dont get me... started..
Sweet glorious cable and FIOS is in reach..
On the other 1/2 of the complex...
Our building has DSL on offer it crashes like every 20 God@:'ng and seconds.. )
Yet the cable co/landlord cant seemed to bother.
Any rate the libray or other spots I can leach from , and leave..
[the lack of stability of interwebs...
No MMO'S ether.. need dragons necks to wring.. else I get cranky.. ]
Wile you can do this manually, having to
Lug an hdmi screen etc till you get console over ssh cooking over ethernet..
Get eth0:1 @ static ip (clone) for ssh wifi ..
And LCD driver as needed would be a plus.
On to do list.
Hopefully if I can rebuild the kernel modules, can get LCD and logitech dongle for mouse and kb to work.. less obtuse with case batteries in case.
Ie more portable, hit the wifi picker
Hit firefox..
Run chroot script get sources. Over Public wifi .. set up ssh @ home and build.
Sent from my SM-N960U using Tapatalk
Hi necrose99
Packages are managed through pkgtools or slackpkg
youtube runs through 720p (via CPU 40%) 1080p (via CPU 90%) - firefox
video is played perfectly up to 4k inclusive via mpv rkmpp (CPU up to 45%)
[Image: 15178162.png]
[Image: 15178163.png]
update:
     - glibc 2.29
     - kernel 4.4.172
     - pcie - work (00:00.0 PCI bridge: Fuzhou Rockchip Electronics Co., Ltd Device 0100)
     - wifi/bt - does not work
     - video hardware decoding via mpv
       configured by default to output video via x11 (divx/xvid)
       using profile --profile=rkmpp play video MPEG-1, MPEG-2, MPEG-4, H.263, H.264, H.265, VC-1, VP9, VP8, MVC
slack-current-aarch64-miniroot_01Feb19-4.4.172-rockpro64-build-20190201.img.xz
slack-current-aarch64-miniroot_01Feb19-4.4.172-rockpro64-build-20190201.img.xz.md5
slack-current-aarch64-xfce_01Feb19-4.4.172-rockpro64-build-20190201.img.xz
slack-current-aarch64-xfce_01Feb19-4.4.172-rockpro64-build-20190201.img.xz.md5
Wink
The system does not start. I tried two versions.
I installed on MMC memory.
https://zapodaj.net/1c0737f8a0c97.jpg.html
(02-03-2019, 06:17 AM)festor89 Wrote: The system does not start. I tried two versions.
hi,
when installed on mms, you need to fix:
       >> mount /dev/mmcblk0p1 /media
       >> echo "rootdev=/dev/mmcblk0p1" >> /media/boot/uEnv.txt
       >> sed -i 's:mmcblk1p1:mmcblk0p1:' /media/etc/fstab
README.TXT
Updated Slackware Aarch64 Miniroot (ROCKPro64) 20190201 on Wiki and Pine64 Installer
Updated Slackware Aarch64 XFCE (ROCKPro64) 20190201 on Wiki and Pine64 Installer
  irradium (based on crux linux) RockPro64 riscv64, aarch64 mara 1 511 03-25-2024, 12:12 PM
  RK3399 PCIe enumeration jhadd 0 282 01-31-2024, 08:56 AM
Last Post: jhadd
  yocto for RockPro64 Fide 1 731 01-16-2024, 10:01 AM
Last Post: Fide
  Installing Ubuntu Server on RockPro64 deutschlmao 2 2,649 10-29-2023, 04:43 PM
Last Post: brotherj4mes
  Vanilla mainline Debian 11 (Bullseye) on the RockPro64 Pete Tandy 22 17,501 08-16-2023, 01:34 AM
Last Post: varac
  How to enable CoreSight ETM trace on RockPro64 shpark 0 598 05-21-2023, 11:34 PM
Last Post: shpark
  rk3399 and Visual Output Processor 2 (VOP2) swan 3 1,402 05-13-2023, 12:01 AM
Last Post: swan
  Rockpro64 Dead on arrival? quixoticgeek 1 964 03-12-2023, 06:55 PM
Last Post: quixoticgeek
  RockPro64 boot questions misterc 3 1,599 01-13-2023, 06:21 PM
Last Post: misterc
  A fix for Bluetooth audio stuttering on the RockPro64 raph 2 1,679 01-03-2023, 06:53 PM
Last Post: raph
