Rock64 With Android TV 7.1 Won't boot using 3.5mm power barrel
I can only get the Rock64 to boot with a USB A-2-A cable. If I plug in a cable to the barrel it won't boot.
I am using this for power: https://www.tronsmart.com/products/w2ptu...ll-charger
With a cable like this: https://www.amazon.ca/Duttek-3-5x1-35-Ch...ower&psc=1
[url=https://www.amazon.ca/Duttek-3-5x1-35-Charging-Electronics-Converter/dp/B07DL1DV7T/ref=sr_1_1_sspa?ie=UTF8&qid=1542236800&sr=8-1-spons&keywords=usb-a+3.5mm+power&psc=1][/url]
Would the only reason be that the USB-A port on this charger is not providing 5V-3A? If I use this adapter should I get a USB-C to USB-A cable to make this adapter work?
(11-14-2018, 05:09 PM)Eric82 Wrote: I can only get the Rock64 to boot with a USB A-2-A cable. If I plug in a cable to the barrel it won't boot.
Some USB charging power source only supply 2A current to the device that it recognized and by default just supply 500mA. We always advise user not using the USB charger to power Single Board Computer.
  Rock64 Android Oreo 8.1 TV-Install adventures (Now Android 9.0) Rocklobster 5 5,101 08-04-2021, 07:35 PM
Last Post: Rocklobster
  How do I prepare/put Android on an SD card using etcher cdotsubo3000 3 5,908 06-27-2021, 02:43 PM
Last Post: clach04
  Android and SD Card gigagames 2 4,476 06-27-2021, 02:38 PM
Last Post: clach04
  Android Images (ROCK64) pineadmin 73 166,813 05-04-2021, 01:58 AM
Last Post: zet_lab
  Android 9.0 and Pluto on Rock64-1G missdeenola 1 3,943 03-12-2021, 01:38 PM
Last Post: Wizzard
  broken android microsd images jbach50 1 3,428 01-16-2021, 09:57 PM
Last Post: jimsurvak
  Android on Rock64 SD Problem ElBoluTony 3 5,885 10-07-2020, 12:10 PM
Last Post: ElBoluTony
  Error! Android Rockchip tools method BowerR64 0 2,528 09-18-2020, 08:12 PM
Last Post: BowerR64
Lightbulb Any older versions of Android for the Rock64? BowerR64 2 4,638 09-18-2020, 07:58 PM
Last Post: BowerR64
  Can't boot android 9 on rock64 maks2204 5 8,628 09-09-2020, 08:44 AM
Last Post: BowerR64
