RockPro64 as PVR/DVR
I was looking at building a dvr to record tv useing a tv tuner. I came across the rockpro 64 and am impressed. I am wondering if it is a good idea to use the rockpro for this task. I would preforably be useing the Hauppauge 1265 PCIE tuner but am afraid the rockpro might not support it. If not what about the usb Hauppauge 955Q tuner? Has anyone done a similar project to this?
I'm still in the setup-phase of my rockpro64 based NAS and server, but the DVR function is successfully running with two identical USB sticks (PCTV tripleStick HD 292e TV Tuner). I'm using tvheadend in docker to record the programme.
Integration with kodi and tvhclient is also working as normal. I did similar before with my Synology DS214+ and Raspberry Pi 3 B.
I'm using armbian on the rockpro64 as the host OS. I needed to take the firmware drivers from my Rapsberry Pi OSMC installation and placing them in /lib/firmware.
I did a quick look to your HW, I think for the USB one of yours, it should be similar as seem here. https://www.linuxtv.org/wiki/index.php/H...V-HVR-955Q
Also please note that you have plenty of power on the rockpro64 so it is not a problem to add more services there.
M
Brick Logical Extensible Gizmo Organizing RockPro64 Enclosure hoarfrosty 0 465 08-06-2023, 09:32 PM
Last Post: hoarfrosty
  RockPro64 programing GPIO by Rust yanagawa3 0 1,484 11-24-2021, 08:43 PM
Last Post: yanagawa3
Photo RockPro64 programing GPIO, I2C,UART and SPI madhuks 3 6,418 08-06-2020, 09:07 AM
Last Post: Gienek
  RockPro64 as PATA/SATA bridge? Count Omega 1 4,251 12-07-2019, 02:25 PM
Last Post: Count Omega
Question HOW TO fix Wifi on RockPro64 - Recalbox OS and upload roms on SSD External Gouki 6 8,663 08-25-2019, 05:13 AM
Last Post: Gouki
  ROCKPRO64 for SCRAPING Ulthor_31 4 7,446 08-01-2019, 05:19 AM
Last Post: Ulthor_31
