Pinebook 1080: US keymap for \ | (backslash pipe) key near left shift?
I have a Pinebook 1080 11.6", and there is a key which doesn't map correctly.
I searched and found no answer, hopefully this has already been answered though.
Near my left shift key, I have a key with \ on the bottom and | on top, which are backslash and pipe.
However, when I use it to type, I get this:
> (with shift)
I don't know much about keymaps because I'm in the US and it always "just worked".
Same here.
(11-11-2018, 07:40 AM)acruhl Wrote: I have a Pinebook 1080 11.6", and there is a key which doesn't map correctly.
> (with shift)
Same here (1080 11").
xev reports it's keycode 94, XKeysymToKeycode returns keycode: 60, XLookupString gives 1 bytes: (3e) ">"  (I think that was shifted, btw).
I tried using "keycode 94 = backslash bar", but it didn't seem to work.
xkeycaps didn't work either, with an X protocol error when it sent the X_SetModifierMapping request.  I suspect that was the crazy number of modifiers it was trying to set though.
hrm.
perhaps it needs to be hacked using xkb instead?  i'll need to research that.
> (with shift)
Yep, the 11" has an odd placement of some of the chars (like ' and ") BUT your CAN remap the \ | key using the following:
# remap Pipe Key to Pipe
xmodmap -e "keycode  94 = backslash bar backslash bar"
Put it in your .bashrc and it will be there the next time you login.
Stop this insanity and use "English (US, alt. intl.)" as your keyboard layout Big Grin
An even _better_ solution!
(11-18-2018, 12:20 AM)Noxmiles Wrote: Stop this insanity and use "English (US, alt. intl.)" as your keyboard layout Big Grin
oh my god
thank you for saving my life.
For future reference, this is what I set my keyboard to so the apostrophe was the correct one. At least for me.
Layout: English (US)
Variant: English (US, international AltGr Unicode combining, alternative)
I did that and now the apostrophe or double quote only works every other time I press the key. This is weird. They are in bpue on the - key and I have to use Fn.
I might go back to the regular layout and just deal with it. Or just try the keymap for that particular key.
I suggest looking at the post above yours. I had the same problem and I fixed it.
  Dead Pinebook - fix it or spare parts? oloturia 2 2,297 03-19-2023, 03:38 PM
Last Post: oloturia
  Broken bottom case of PineBook 14 Mick 1 990 02-22-2023, 05:49 AM
Last Post: Mick
  Original 14" Pinebook an Orphan? vdicarlo 2 1,340 01-05-2023, 10:42 AM
Last Post: jezek
  Pinebook Users are a nobody leperotero 13 12,979 09-06-2022, 09:29 PM
Last Post: zapper
  Does anybody repair pinebook pro laptops for a fee? Tsvi Bar-David 0 1,019 09-05-2022, 07:49 PM
Last Post: Tsvi Bar-David
  Pinebook with a broken screen and 2 eMMC's for sale. UK ONLY. frank-zappa 0 1,656 03-08-2022, 10:14 AM
Last Post: frank-zappa
  Pinebook to Pinebook Pro-esque upgrade kit sebboh 5 7,676 08-18-2021, 11:01 PM
Last Post: Corkonian
  new pinebook help ron_burgundy 5 7,835 12-17-2020, 04:54 PM
Last Post: ron_burgundy
  Few questions about flashing to a MicroSD card on the Pinebook Pro SanjevR 6 9,788 12-07-2020, 04:02 PM
Last Post: SanjevR
  TOR Browser on the Pinebook Pro jay3gg 0 3,028 11-16-2020, 01:25 AM
Last Post: jay3gg
