WiFi BT module antenna location NAS case
Question
For the life of me, I cannot find the location described in the wiki for the antenna locations. It says:
Quote: In the back section of the case at the very top you will find three cut-outs where the SMA antennas can be fitted.
Huh
I have the module purchased from ameridroid. I'm sure I will kick myself when I learn where these things are. Thanks in advance!
Dont have a NAS myself, but guess this view (on Pine64 store) shows the 3 holes along the top edge?
(10-22-2018, 04:53 PM)dukla2000 Wrote: Dont have a NAS myself, but guess this view (on Pine64 store) shows the 3 holes along the top edge?
Thanks for this...I suppose you are right. Too bad though as I just learned I cannot use the module with the PCI Sata board with OMV. Hopefully I did my homework right and the USB wireless chipset has a supported driver.
Thanks again!
  AW-CM256SM wifi card mtek 4 2,349 10-30-2023, 12:00 PM
Last Post: diederik
  U.FL plug on the Wifi/BT module? domih 8 12,778 10-17-2022, 04:43 AM
Last Post: callegar
  Pine Wifi Module williamdieter 2 2,765 07-20-2022, 03:31 AM
Last Post: imianz
  NAS case HDD power cable failure (buck failure) ashleymills 1 1,911 04-01-2022, 11:25 AM
Last Post: ashleymills
  Plugging In Case Fan and CPU Fan publiclewdness 0 1,428 01-04-2022, 09:58 AM
Last Post: publiclewdness
  Nas Case out of stock Goffi 2 2,270 12-04-2021, 05:14 AM
Last Post: Goffi
  To Wifi or To Bluetooth, That is the Question WarpLover 0 1,576 07-06-2021, 08:45 PM
Last Post: WarpLover
  RP64 TV box case with wifi Wizzard 2 3,295 03-10-2021, 12:23 AM
Last Post: Wizzard
Question 1U Rackmount Case for ROCKPro64 tuaris 3 5,013 02-18-2021, 08:09 PM
Last Post: TRS-80
  NAS Case: Issues with hardware installation, esp. screws kuleszdl 0 1,728 01-09-2021, 05:24 PM
Last Post: kuleszdl
