04-30-2020, 06:56 AM
oh fair enough i guess,
Install Playstore on Android 8.1.0
04-30-2020, 06:57 AM
got playstore installed on android 9 and installed chrome problem is 9 keeps rebooting not sure if its from 9 or because i installed the three apps plus chrome
04-30-2020, 10:07 AM
05-13-2020, 12:16 PM
if we follow the instructions for the tinkerboard, we need the services for android 9,
GSF for 9-5252573 Google Play Store 14.2.58 Google Play Services 15.1.81 - arm64-v8a + armeabi-v7a (nodpi) these are the ones I am using. the play store and play services were released at the end of march 2019 and the GSF was released for Android 9 on april 2, 2019 some critical notes Instruction set is: arm64-v8a SDK: 28 resolution is: 1024x552 pixels Density is: 160 dpi Refresh Rate: 58 hz
04-16-2021, 02:13 AM
I played with it a little and I successfully installed Play Store using apks downloaded from apkmirror.
At a time of writing this post there are these versions: https://www.apkmirror.com/apk/google-inc...-download/ https://www.apkmirror.com/apk/google-inc...-download/ https://www.apkmirror.com/apk/google-inc...-download/ I just renamed the files to playstore.apk, playservices.apk and gsf.apk and installed using this guide. I decompressed the renamed playstore.apk to playstore.apk.zip and copied all the libs via adb. So Play Store works. |
Android images for RockPro64 | BitAnnihilator | 1 | 30 |
04-17-2024, 07:50 AM Last Post: tophneal |
Difficulty installing Android on Rockpro64 | spammycheese | 0 | 2,792 |
02-17-2023, 05:31 AM Last Post: spammycheese |
Using Android and the Playstore | grobbs | 0 | 2,635 |
06-04-2022, 12:18 AM Last Post: grobbs |
Android TV | miguelangelaj | 2 | 3,005 |
06-03-2022, 11:23 AM Last Post: miguelangelaj |
Control Fan in Android | miguelangelaj | 2 | 2,436 |
06-03-2022, 11:22 AM Last Post: miguelangelaj |
Slash TV Android for RockPro64 | Wizzard | 12 | 11,033 |
04-24-2022, 08:13 AM Last Post: Rocklobster |
DRM support in Android | Wizzard | 2 | 2,680 |
02-03-2022, 09:16 PM Last Post: Johnmo89 |
Install Playstore on Android 7.1.2 | Domo | 6 | 14,016 |
04-16-2021, 02:10 AM Last Post: Wizzard |
Kodi crashing in Android 9 | Wizzard | 2 | 4,005 |
04-16-2021, 02:03 AM Last Post: Wizzard |
Install Playstore on Android 9 image | ddimension | 18 | 27,894 |
02-13-2021, 12:52 AM Last Post: chisteven |
