Pinebook won't charge
I have been away from home for a long time and haven't used my Pinebook. I have read that an amber light would indicate the battery is charging. This light doesn't turn on, even after inserting the power cable multiple times (>10).
I have been searching the internet for a replacement battery, but the model number can not be found. The voltage 4.35V is also an unusual number. It seems that voltages are always a multiple of 3.7V.
Is there anyway I can reanimate my Pinebook? Or have I been robbed of my money with a now useless product. Angry
Have you tried to charge it for some hours? I have had this, too, but after ~2 hours of charging it worked again (After ~1h it showed the battery logo for some seconds when pressing the power button, but it did not start).
(10-19-2018, 01:51 AM)Juwie Wrote: Have you tried to charge it for some hours? I have had this, too, but after ~2 hours of charging it worked again (After ~1h it showed the battery logo for some seconds when pressing the power button, but it did not start).
I have opened the Pinebook and unplugged the battery (read that solution somewhere), plugged it back in.
When I inserted the power adaptor the battery indicator with a lightning flash appeared shortly. I left the Pinebook like that for a whole night and this morning it started up again with a fully charged battery. With the adaptor unplugged it had roughly 6 hours of battery charge. I can't remember if that was the same as when I got the Pinebook. I am happy again  Smile and will make sure not to drain the battery to 0%.
I will just gently point out that reading this post would offered up the answer...
Mark the thread as solved for future users.
(10-19-2018, 05:46 AM)Luke Wrote: I will just gently point out that reading this post would offered up the answer...
Problem solved, however I didn't have the power plug connected while unplugging the battery from the Pinebook.
  pinebook 1080p power/barrel connector/cable cel 0 535 08-03-2023, 11:43 AM
Last Post: cel
  eMMC compatible with Pinebook leperotero 0 1,361 07-19-2022, 07:15 AM
Last Post: leperotero
Heart [solved] Anyone selling their Pinebook? feyn 0 1,213 07-11-2022, 03:38 PM
Last Post: feyn
  Move PB Pro eMMC 128 GB to Pinebook 11 1080p petet0n76 1 1,614 06-07-2022, 10:35 PM
  UART switch Pinebook 11.6" irongarment 3 3,290 01-03-2022, 03:28 AM
Last Post: kqlnut
Exclamation "6" Key direly needed for 11" Pinebook Corkonian 1 2,591 09-25-2021, 12:03 AM
  Pinebook 14 " Battery Swollen/Bulged billjon 1 3,587 01-13-2021, 11:03 AM
Last Post: barray
  touchpad on pinebook issues? ron_burgundy 14 13,711 12-19-2020, 06:55 PM
Last Post: ron_burgundy
  Pinebook doesn't charge anymore Reinoud 0 2,664 08-20-2020, 08:18 AM
Last Post: Reinoud
Information How To Setup Serial Console Cable Over the Pinebook MarkHaysHarris777 4 22,846 07-02-2020, 06:33 PM
