Detailed NAS Case assembly (ameriDroid)
(04-25-2019, 01:11 AM)Luke Wrote:
(04-24-2019, 03:16 PM)g_t_j Wrote: Does anyone know if 4 HDDs (2 x 3.5 + 2 x 2.5) can be fitted in the case?
It can. You just need to figure out how to power 4 drives. Also (I am stating the obvious) you need a PCIe SATA adapter with 4 ports which would work.
Hm... yes you're right. Somehow I was under the impression there are 4 inputs on that PCIe card. (I'm still waiting for my order)
I guess if there a HAT providing 2 x USB 3.0 inputs, the above build would have been doable!
Hello, quite new on the forum and I looking into buying a rockpro to hos a relisio.
Instead of HDD I want to Use SSD and therefore the ROCKPro64 PCI-e X4 to M.2/NGFF NVMe SSD Interface Card
would it fit in the NAS box? I would assume so but just wanted to have confirmation prior to ordering one.
thanks!
(08-10-2019, 06:49 AM)vorondil Wrote: Hello, quite new on the forum and I looking into buying a rockpro to hos a relisio.
thanks!
should fit, you can only install one NVMe SSD.
It's a cute little SATA card that sells in the PINE store. Might take a little looking to find another one that fits in the case, but I know there are people running 4, 5 or maybe more disks off of such a card. Once I play with this a ilttle while, I might look into building another for more disks.
The multiple NVME cards I've used require setting PCIe bifurcation (or dual bifurcation for 4X) in the BIOs, I have no idea whether there's an equivalent way to use the slot on the RockPro64
it doesn't get happy
it doesn't get sad
it just runs programs
Read from reddit that someone is trying to build a router using an Intel PCI-E dual Ethernet card out of the case.
I'd like to know if someone can confirm if there's enough room for a standard PCI-E Ethernet card?
(10-01-2020, 04:40 PM)Enig123 Wrote: Read from reddit that someone is trying to build a router using an Intel PCI-E dual Ethernet card out of the case.
I only have access to older Intel dual gigabit cards (PRO/1000 PT) and with it's length of 130 mm it would fit but it would be touching the case (so I wouldn't do it). Smile
The bracket (the metal piece where you put the screw) is smaller, I measure it to be 80 mm which should match the standard of the "PCI Low-Profile bracket".
A bit of searching shows that there are a number of cards out there that would fit, although I didn't find any IntelConfused
  Anyone require a apple-sleek NAS case, w/ ample passive cooling & mutliple ssds? dairymilkbatman 0 219 01-19-2024, 02:17 PM
Last Post: dairymilkbatman
  3D Printed 2 SSD Vertical NAS Case tenox 1 2,125 12-19-2021, 01:30 PM
Last Post: CounterPillow
  [Turorial] NAS Using A Recycled 1U Proliant Case ColPanic_ 1 2,733 06-02-2021, 12:51 AM
Last Post: LMM
  NAS/fileserver project—RP64 in 1U ATX/ITX case (comments welcome!) Skirmisher 10 13,460 04-09-2021, 01:37 AM
Last Post: MNtinkerer
  Ideas to use extra space in NAS case? _hg_ 1 3,262 10-04-2020, 11:42 PM
Last Post: zer0sig
