What do i use the pinebook for?
(09-28-2018, 01:26 PM)Wizzard Wrote: I am not sure what do you think, but I removed all the obsolete packages using autoremove.
I forgot autoremove. Especially as you used apt to perform a full upgrade, I think that would suffice at purging all the legacy xenial packages.
What comes out if you run lsb_release -a?
[ PHP Developer | Pinebook 1G | About me ]
what about this, after ensuring packages are up to date:
sudo apt install update-manager-core
sudo do-release-upgrade
(09-28-2018, 02:07 AM)Wizzard Wrote:
(09-26-2018, 09:19 PM)icemeister Wrote:
(09-26-2018, 01:32 AM)Wizzard Wrote: You can easily upgrade to Ubuntu 18.04 and even 18.10, I have tested it and it works well.
How would one go about doing an upgrade? I would love to use the pinebook with a vpn(i found out my vpn service can be used in firefox and works on the pinebook) to play out on the net. and do stuff.
Just edit "/etc/apt/sources.list" file and replace "xenial" by "bionic" or better by "cosmic", then run "sudo apt update" and "sudo apt dist-upgrade" and you are done.
Maybe you will have to solve some issues during upgrade, just read carefully what it writes and do what is necessary, or paste it here and we will help you.
Thanks I will try this and see how much trouble i can get into
(09-28-2018, 01:46 PM)soupbowl Wrote: What comes out if you run lsb_release -a?
I am sure it is Ubuntu 18.10, but forgot to check yesterday, will try today Smile
edit:
pine64@pinebook:~$ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu Cosmic Cuttlefish (development branch)
Release: 18.10
Codename: cosmic
edit: So I actually sold my PB and will switch to some more powerfull device. Pinebook is a good piece of HW worth 100 €, but not more and not suitable for everyday work (as everybody knows).
Before i could try your upgrade pinebook did it on its own. Told me i was using an outdated ubuntu and ask if i wanted to upgrade. I said yes and now i have bionic and mate desktop. i am missing a desktop vpn service, and i liked tomboy notes it is also gone. so i need to play with this and see what it can do.
Thanks i will keep playing with this
  Dead Pinebook - fix it or spare parts? oloturia 2 2,291 03-19-2023, 03:38 PM
Last Post: oloturia
  Broken bottom case of PineBook 14 Mick 1 986 02-22-2023, 05:49 AM
Last Post: Mick
  Original 14" Pinebook an Orphan? vdicarlo 2 1,339 01-05-2023, 10:42 AM
Last Post: jezek
  Pinebook Users are a nobody leperotero 13 12,949 09-06-2022, 09:29 PM
Last Post: zapper
  Does anybody repair pinebook pro laptops for a fee? Tsvi Bar-David 0 1,014 09-05-2022, 07:49 PM
Last Post: Tsvi Bar-David
  Pinebook with a broken screen and 2 eMMC's for sale. UK ONLY. frank-zappa 0 1,653 03-08-2022, 10:14 AM
Last Post: frank-zappa
  Pinebook to Pinebook Pro-esque upgrade kit sebboh 5 7,666 08-18-2021, 11:01 PM
Last Post: Corkonian
  new pinebook help ron_burgundy 5 7,822 12-17-2020, 04:54 PM
Last Post: ron_burgundy
  Few questions about flashing to a MicroSD card on the Pinebook Pro SanjevR 6 9,777 12-07-2020, 04:02 PM
Last Post: SanjevR
  TOR Browser on the Pinebook Pro jay3gg 0 3,027 11-16-2020, 01:25 AM
Last Post: jay3gg
