eMMC support
Supported 128GB eMMC 5.1 Module for ODroid XU3/XU4?
  • eMMC Version 5.1 interface from Sandisk/Toshiba
  • JEDEC/MMCA Version 5.1: HS400 interface with 8bit DDR mode
https://ameridroid.com/products/emmc-5-1...5895630882
https://www.hardkernel.com/main/products/prdt_info.php?g_code=G150825660587
Should be OK - the Pine64 shop for the RockPro64 says 128GB is OK (even though the highest capacity they sell is 64GB). And Odroid eMMC has been reported fine on these forums at other capacities.
My 6p, if you are not planning SATA (or something else) for the PCIe, and you are planning Linux, is go NVMe. Plenty of used modules on Fleabay from folks upgrading laptops at better prices than eMMC. Even new 2nd tier ones are competitively priced compared to eMMC. And performance is order of magnitude better. It does require some investment learning all the specs/jargon and seems scary but I did, and am so glad I did.
(09-23-2018, 06:19 AM)dukla2000 Wrote: Should be OK - the Pine64 shop for the RockPro64 says 128GB is OK (even though the highest capacity they sell is 64GB). And Odroid eMMC has been reported fine on these forums at other capacities.
Good idea! Thank you very much!
Maybe can Android also support it?
  Can i use this Emmc for Rockpro 64 Supratec 0 446 09-02-2023, 06:38 AM
Last Post: Supratec
  PCIe bifurcation support (on RK3399) Arn 1 1,336 11-28-2022, 05:12 PM
  Pad to level Emmc like the PineBook Pro JessicaQ 0 1,039 08-18-2022, 12:28 PM
Last Post: JessicaQ
  Support for Refresh rates Above 60 publiclewdness 0 1,267 01-01-2022, 11:40 PM
Last Post: publiclewdness
  PCI-E X4 to M.2/NGFF NVMe SSD - support? AndyOfLinux 22 28,363 12-13-2021, 11:04 AM
Last Post: Cerberus
  PCI Express x4 Device Support machinevault 4 7,405 07-13-2020, 01:32 PM
Last Post: pgwipeout
  eMMC can't be recognize after 6 months idle seanlee 10 11,279 12-24-2019, 04:35 AM
Last Post: abdel
  Emmc issue? stuartiannaylor 6 7,498 08-16-2019, 06:41 AM
Last Post: stuartiannaylor
  Need to add various Wifi chipset support slappymcphee 6 8,107 08-15-2019, 05:26 PM
Last Post: evilbunny
  JMicron cipset SATA PCI-E card support Yroth 2 4,028 07-27-2019, 08:52 PM
