are the usb ports on rock64 on separate bus?
Are all the USB ports on the rock64 on separate bus. I dont have a rock64, else I could check using lsusb on linux.
I need to connect camera and a sensor on two different USB ports. If they are on the same bus it results to decreased or dropped frames from the camera.
If anyone operating linux on rock64 can give me the output of lsusb command, it would be helpful.
(09-21-2018, 10:57 PM)shome Wrote: Are all the USB ports on the rock64 on separate bus. I dont have a rock64, else I could check using lsusb on linux.
# lsusb  -t
/:  Bus 05.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 5000M
   |__ Port 1: Dev 2, If 0, Class=Mass Storage, Driver=usb-storage, 5000M
/:  Bus 04.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 480M
/:  Bus 03.Port 1: Dev 1, Class=root_hub, Driver=ohci-platform/1p, 12M
/:  Bus 02.Port 1: Dev 1, Class=root_hub, Driver=ehci-platform/1p, 480M
   |__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/4p, 480M
       |__ Port 1: Dev 3, If 0, Class=Hub, Driver=hub/4p, 480M
       |__ Port 2: Dev 7, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M
       |__ Port 2: Dev 7, If 1, Class=Human Interface Device, Driver=usbhid, 1.5M
       |__ Port 3: Dev 5, If 0, Class=Vendor Specific Class, Driver=cp210x, 12M
       |__ Port 4: Dev 6, If 0, Class=Vendor Specific Class, Driver=ftdi_sio, 12M
/:  Bus 01.Port 1: Dev 1, Class=root_hub, Driver=dwc2/1p, 480M
  Are HW design files available for ROCK64? irenek 3 4,749 12-11-2023, 09:31 PM
  Rock64 is unreliable after 3 years of service - power problem? ReleaseTheGeese 0 329 11-23-2023, 05:05 AM
Last Post: ReleaseTheGeese
  Rock64 PoE compatbility with Pi4 Hatt recent Single Board Computer offering from PINE kharak 1 1,060 04-26-2023, 11:38 PM
  Case for the rock64 that supports the POE hat. o1CRiMSON1o 0 619 03-21-2023, 03:48 PM
Last Post: o1CRiMSON1o
Brick Rock64 usb2.0 Power Control Floating GPIO Tutorial Files & Notes MarkHaysHarris777 6 13,212 01-15-2023, 10:36 AM
Last Post: ds00
  rock64 totally brick dakobg 2 1,733 11-07-2022, 05:45 PM
Last Post: olivercfc
  3D-Printable Button Pegs for the ROCK64 Aluminium Case CounterPillow 2 3,514 08-04-2022, 01:31 AM
Last Post: Vicky Weimann PhD
  Where can I find the ROCK64 POE HAT Zoz 2 2,609 06-08-2022, 12:44 AM
Last Post: Zoz
Smile wooden case for ROCK64 killor 13 16,496 03-04-2022, 06:56 AM
Last Post: killor
  1wire DS18b20 on Rock64? mypineme 6 7,024 09-28-2021, 03:07 PM
Last Post: TRS-80
