Gentoo, Current state, Test Phase
Thumbs Up
(11-21-2018, 01:34 PM)khaosgrille Wrote:
(10-26-2018, 05:50 AM)tux_on_tour Wrote: As of friday 26.10.2018 the image has no partition table.
sorry for no response for such a long time. I forked ayufans building script and will release the first version soon.
It is working right now but i need to clean it up a little bit.
I changed the first post with a bunch of new updates.
Khaosgrille
Thanks for your hard work.
I had up till now only limited success building my own gentoo install as I did not get the network connection to run.
I think that I wait till you made a working version so I can brake it again trying to optimize it.
tux_on_tour
quick update from me. I had few problems with scripting the last steps. I have given up (quite early honestly) and  done them by hand  and here is an image (https://grmr.de/khaosgrille/gentoo3.img.tar.xz)
I  only made a minimal image without X or any tweaks. If u use a sd card as a medium I strongly recommend using TMPDIR on tmpfs.
SD Cards have not enough space/inodes and compiling several packages in a row is nearly impossible.
(https://wiki.gentoo.org/wiki/Portage_TMPDIR_on_tmpfs)
If everything works fine I will make a bigger announcement in the forum. I would like feedback and hear about things you would like to add.
The /boot dir is currently not quite working in the script (but in the image). Sadly I will be to busy to finish the script.   I just copied the /boot and the /boot/efi/ from ayufans ubuntu^^.
Greetings
Khaosgrille
PS: The image is for 16gb SD cards and is with DHCPCD aswell as the arm/17.0/Desktop profile.
EDIT: username is root and pw is "rock64"
packages.. built...
arm64 systemd desktop profile used..
http://dpaste.com/29VXCY2.txt
[/quote]
  How to reset board to default state? kkdao 4 5,948 09-01-2020, 05:48 AM
Last Post: kkdao
  Anyone running Gentoo? N1ESE 1 3,619 05-12-2020, 07:27 AM
Last Post: khaosgrille
  Call for test: Clonezilla live for Rockpro64 stevenshiau 1 4,755 04-17-2020, 12:38 AM
  ARM CPU Stress Test jzhang18 14 16,676 08-31-2018, 12:54 PM
Last Post: jzhang18
