Encountering Problems
So, the actual operating system works great! But every single application loads extreamely slow, if it does at all. Once it loads its fine and dandy but sometimes it seems like any application will just work itself into the ground and stop unexpectedly. Anyone encountering the same issue?
If you could provide some more information it would be easier to take a look at.
one or two Gb Ram
buildnumber on the ROM
addons
(04-15-2016, 12:59 AM)Anunnaki Wrote: Anyone encountering the same issue?
Yeah, me. By replacing the crappy old SD card with a new one showing superiour random I/O performance I was able to solve the problem: http://forum.armbian.com/index.php/topic...rformance/
This is a good point. A lot of us are spoiled by a nice smart phone that has nand that running much faster than most if not all microSD cards. This can really lead to a lot of, but my android phone is this much faster, my tablet can run this game smooth, why cant the pine? Etc.
I spent a lot of money on a good sd card, I have the 2g of ram and a wifi module, maybe the wifi module is sucking energy? It shouldnt be because im using my nexus 6 super charger as a power supply.
'nexus 6 super charger' might be the reason for undercurrent problems leading to stability problems. Measure the amperage available and compare with 'smart USB chargers' here. If you can't measure try it without the WiFi module and connect any energy hungry USB peripheral. If the board doesn't boot any more you know the reason.
  Android 6.0.1 (LCD Panel version) reboot problems Maxim0n 3 4,951 06-26-2017, 07:21 AM
Last Post: pfeerick
  android image & sd card size problems tomarneson 11 17,751 01-24-2017, 05:31 AM
Last Post: ayufan
  Problems Connecting to Google Services? GunnerKB 0 1,756 05-01-2016, 10:56 AM
Last Post: GunnerKB
Shocked Haaalp! Any experience with Pine64 Android problems! ebreake 15 16,571 04-13-2016, 09:55 AM
Last Post: ebreake
