Pinebook accessories (emmc usb card)
If I see the "options available" correct for the Pinebook, it shows an EMMC _USB card to mount the upgrade/purchased 64gb EMMC and ai can etch it directly to the EMMC.... allowing me access to install it into the Pinebook.  (Am I seeing that correctly?  (Is the Pinebook internal accessible to install the larger flashed 64mb EMMC myself?)
If not, then I do not need the EMMC_USB card for flashing EMMC memory internal to the PINEBOOK.
2) Micro SD sdxc Class 10 memory.  Other vendors also show and reference the SD-UHS1 class 10 card as a double performance in read and write over the offered Class 10 sdxc card.
As long as it is class 10, it should be identifiable, I assume the increase in read/write will be the same on PineBook.
(ANYONE VERIFY THAT AS BEING THE CASE FOR PINEBOOK OR PINE CARDS?)
3) WHAT IS THE LARGEST Micro sdxc in MB the Pinebook can identify? 256mb or higher?
4)I will image the EMMC with the OS.  Can I specify the MicroSD as data storage location? in addition to using the EMMC for OS/Programs.
5) I have nice Linux Nas(2) I will backup the Pinebook to regularly.
I need to identify software that will allow me to map/see network and attach to / map to external drives (nas). Unless that is included in KUBUNTU.  I am just now starting to read up on it.
If you have any specific info to direct me to please do so.  I called myself looking THOROUGHLY through website for specific answers abut none were shown.
Thank you again,
Alton
  pinebook 1080p power/barrel connector/cable cel 0 535 08-03-2023, 11:43 AM
Last Post: cel
  eMMC compatible with Pinebook leperotero 0 1,363 07-19-2022, 07:15 AM
Last Post: leperotero
Heart [solved] Anyone selling their Pinebook? feyn 0 1,213 07-11-2022, 03:38 PM
Last Post: feyn
  Move PB Pro eMMC 128 GB to Pinebook 11 1080p petet0n76 1 1,615 06-07-2022, 10:35 PM
  UART switch Pinebook 11.6" irongarment 3 3,293 01-03-2022, 03:28 AM
Last Post: kqlnut
  Manjaro/Cinnamon customised on sdcard: how to transfer to emmc? quixote 0 1,509 10-16-2021, 02:03 PM
Last Post: quixote
Exclamation "6" Key direly needed for 11" Pinebook Corkonian 1 2,591 09-25-2021, 12:03 AM
  SD card read/write troubles jezek 1 2,969 03-26-2021, 09:27 AM
Last Post: jezek
  Pinebook 14 " Battery Swollen/Bulged billjon 1 3,587 01-13-2021, 11:03 AM
Last Post: barray
  touchpad on pinebook issues? ron_burgundy 14 13,718 12-19-2020, 06:55 PM
Last Post: ron_burgundy
