PINEBOOK RAM not upgradable
I was registered one month ago and now I get a Coupon Code.
When finally I prepearing accomplish purchase order, I re-checked Specifications and found:
RAM: 2 GB LPDDR3 RAM Memory
Flash: 16 GB eMMC 5.0 (upgradable up to 64GB)
I am glad the Flash upgradable, but I dont't understand why RAM seems not upgradable? ROCK64 SINGLE BOARD COMPUTER has 4GB RAM, but the Pinebook has only 2GB, is it really enough?
RAM is soldered.
ROCK64 has a different CPU and AFAIK CPU from Pinebook does not support 4GB of RAM
Correct, different SOC (AllWinner A64).
(09-11-2018, 05:05 AM)Luke Wrote: Correct, different SOC (AllWinner A64).
Thank you, I need to read more about that.
A64 does support 3GB at maximum. But for RAM to be "upgradable", it apparently has to have SODIMM slots. Smile it could, but the price won't be as it is now. happily RAM is a quite long living thing. and 2GB is a gewd amount.
ANT - my hobby OS for x86 and ARM.
3GB of RAM have been discussed. In general, having weight in on the pros and cons, and considered what is worth upgrading while keeping the price at approx $100, the decision was made to improve the LCD. If there ever will be a higher-end Pinebook, then I think that will likely have more RAM, but it will also cater to a different-end use case.
(09-11-2018, 07:06 AM)z4v4l Wrote: A64 does support 3GB at maximum. But for RAM to be "upgradable", it apparently has to have SODIMM slots. Smile it could, but the price won't be as it is now. happily RAM is a quite long living thing. and 2GB is a gewd amount.
Thank you, I had put my order and paid, now waiting my Pinebook should be arrive in mid of Oct. Rolleyes
(09-11-2018, 08:51 AM)Luke Wrote: 3GB of RAM have been discussed. In general, having weight in on the pros and cons, and considered what is worth upgrading while keeping the price at approx $100, the decision was made to improve the LCD. If there ever will be a higher-end Pinebook, then I think that will likely have more RAM, but it will also cater to a different-end use case.
Understand, 1GB of RAM is expensive, but an empty slot is cheap, may be you can add a slot in furture.
Hi @jameling, are you sure that you registered to queue month ago? I registered on August 1st and I didn't received my coupon yet.
(09-11-2018, 11:52 AM)erha Wrote: Hi @jameling, are you sure that you registered to queue month ago? I registered on August 1st and I didn't received my coupon yet.
According my Email record,
received "Account Activation at PINE64" email in Aug 21, so I think I registered that day, and put the order request same day, I am not sure I do it correct, so I put order twice.(Sorry)
I received 2 Email in Sep. 6, title "Meet your New 11.6” Pinebook !" with different Coupon Code.
Yesterday (Sep. 11) I paid 1 with Coupon Code and get email "Your PINE64 order receipt from September 11, 2018"
If you didn't receive Coupon Code, may be lost in record, I think you can make another request.
Thank you for your answer. The next day after I post my question I received my coupon! I already ordered my Pinebook and I'm looking forward to it.
  Dead Pinebook - fix it or spare parts? oloturia 2 2,297 03-19-2023, 03:38 PM
Last Post: oloturia
  Broken bottom case of PineBook 14 Mick 1 990 02-22-2023, 05:49 AM
Last Post: Mick
  Original 14" Pinebook an Orphan? vdicarlo 2 1,340 01-05-2023, 10:42 AM
Last Post: jezek
  Pinebook Users are a nobody leperotero 13 12,973 09-06-2022, 09:29 PM
Last Post: zapper
  Does anybody repair pinebook pro laptops for a fee? Tsvi Bar-David 0 1,019 09-05-2022, 07:49 PM
Last Post: Tsvi Bar-David
  Pinebook with a broken screen and 2 eMMC's for sale. UK ONLY. frank-zappa 0 1,656 03-08-2022, 10:14 AM
Last Post: frank-zappa
  Pinebook to Pinebook Pro-esque upgrade kit sebboh 5 7,675 08-18-2021, 11:01 PM
Last Post: Corkonian
  new pinebook help ron_burgundy 5 7,834 12-17-2020, 04:54 PM
Last Post: ron_burgundy
  Few questions about flashing to a MicroSD card on the Pinebook Pro SanjevR 6 9,788 12-07-2020, 04:02 PM
Last Post: SanjevR
  TOR Browser on the Pinebook Pro jay3gg 0 3,028 11-16-2020, 01:25 AM
Last Post: jay3gg
