3D model for Playbox enclosure
I want to develop a mount for the stereo cameras in the back plate for the Playbox Enclosure. I am wonder if you are willing to share that 3d model for it. when I can modify it and send it back to you.
I have professional license for Sketchup pro and 3D printers to test the design as well.
Here is the model: http://files.pine64.org/doc/datasheet/ca...160426.stp
This is for the Pine A64, but I am pretty sure not that much has changed with regard to the backplate. I'd wait for TL to confirm this for you before starting to work on anything.
(08-28-2018, 03:35 AM)Luke Wrote: Here is the model: http://files.pine64.org/doc/datasheet/ca...160426.stp
The only change is the power connector opening which is the taller by 1.5mm.
Hi Luke,
I like this enclosure but I have one question for my purpose.
Can I mount this enclosure with screws to a wall?
I want to use this for educational purposes.
Lightbulb ROCKPro64 + SSD case model for 3D print Spater 0 1,004 01-27-2023, 07:43 PM
Last Post: Spater
  Waterproof Enclosure Knockout Size faultywarrior 1 2,536 12-13-2020, 08:19 PM
Last Post: faultywarrior
  RockPRO64 Playbox vs PINE64 Playbox Firesped 0 1,887 08-25-2018, 08:23 AM
Last Post: Firesped
