Defective? PCI-E -> SATA card no work good
If you really want a window manager, Bullet64, it turns out i3 will work as of 0.7.9.
1. Install an Ubuntu Bionic minimal image (which you already have)
2. `sudo /usr/local/sbin/install_desktop.sh i3`
3. Uh, learn i3? I'm taking a lot from https://fedoramagazine.org/getting-start...w-manager/
If you are having trouble with PCIe detection and a specific device, I compiled an older mrfixit2001 kernel that works for my device (Silicon Image SiI 3132) whereas the newer kernels do not detect the root PCIe either.
Try the debs.tar.gz here:
https://github.com/digitalsanity/rockchi...-pcie-test
  Mainline U-Boot with SPI, NVMe and SATA boot support sigmaris 108 118,910 09-25-2023, 12:46 AM
Last Post: ChriChri
  Sata HD stopped booting db579 2 2,149 03-11-2022, 03:34 PM
Last Post: db579
  Rockpro64 with PCI FC Card - Not booting (Sometimes) MSteam 1 2,915 10-25-2020, 07:42 PM
Last Post: MSteam
  fan continously runs on kernel 5.8 but I need to use 5. kernel for PCIe sata card GreyLinux 4 5,678 10-20-2020, 10:52 AM
Last Post: GreyLinux
  RockPro64 SSD Expansion Board/SATA Shield as0zial 5 7,586 10-18-2020, 08:05 PM
Last Post: revoman
  4pin Connector for dual SATA m.ekstrom 4 6,174 07-28-2020, 07:07 AM
Last Post: mabs
  micro SD Card Slot Spring not working, Cant boot mjembd 1 3,109 04-16-2020, 12:30 AM
Last Post: mjembd
  Spotify - work arround with librespot-java Helium75 0 2,264 12-08-2019, 06:53 AM
Last Post: Helium75
  for what purpose Pine64 added PCIEx4 card on this sbc ? seaurchin 4 6,002 11-25-2019, 11:33 AM
Last Post: dukla2000
  Shadow Game streaming - does it work? korn2017 1 3,319 06-13-2019, 07:30 PM
