KDE Neon Pinebook remix edition RC image
#31
(09-15-2018, 11:06 AM)junktronix Wrote:
(09-14-2018, 04:18 PM)junktronix Wrote: I haven't had any luck getting this installed on my Pinebook.  I don't have the necessary things to try method 1. This image doesn't seem to have an eMMC flasher, though every time I tried running the first time installation after booting on SD, I ended up with a non-bootable SD.  I also tried method 3, but the KDE Neon image is too large to fit.
I also tried dd'ing the image to the eMMC, but ended up with a non-booting machine.  I backed up / restored the original eMMC contents successfully so I know it should work.  Is the image on kce.org specifically for SD or should it in fact work if copied to the eMMC?
I just ordered a cheap USB to eMMC adapter and will try installing the image on the eMMS with that next.
(08-23-2018, 02:29 PM)Luke Wrote: Not sure what the outlets mean by 'detailed instructions' either. Instructions on how to flash the internal eMMC on the Pinebook can be found here.
But since many sources point online here, I feel compelled to quickly write up the missing kind-of detailed instructions:
In short, you can flash the eMMC on the Pinebook either via: 1) FEL (outline in link above); 2) booting from SD and flashing to eMMC (some OS images have their own installers while on other OS' you have dd the eMMC manually); 3) using a special SD card image (such as this one).
As for 3), its worth mentioning that it can be easily modified to flash any OS image to eMMC by i) flashing the image above to a SD card ii) mounting the rootfs partition of the SD card on your computer (I am assuming you're on *nix) iii) deleting 'pinebook.img' from the partition iv) copying over whatever OS image you want on your Pinebook's eMMC v) renaming the OS image you copied over 'pinebook.img' vi) and lastly putting it into your Pinebook, powering it on and following onscreen instructions (NB disregard that it says 'flashing Ubuntu Mate' -> its actually flashing whatever OS image you placed in the SD rootfs).
I trust this helps.
I got it installed after all.  My method was to install KDE Plasme on both an SD card and a USB thumb drive, then boot on the SD and dd the thumb drive (/dev/sda) to the eMMC.  It's running great and a huge improvement over the stock Xenial.  I noticed that there is no swap enabled, but there is 20MB of unallocated space at the beginning of flash.  I set that up as a swap partition, but the machine wouldn't reboot after that.  Any thoughts on swap space for this release?
The initial space is for things like the bootloader, I would not recommend changing that 'hidden' partition. Instead I recommend installing zram-config.
#32
I trust this helps.
Thanks for the pointer.  I'd set up a swap file, but zram looks like a much better solution.
#33
Wink
Hello. I am Luis from Spain. I have a Pinebook with KDE neon and It,s very fast but feel the next issues: No sound, No hdmi out . I hope the next images. I tried change parametres on uEnv.txt.in but no work. Also I tried with Fbset and no work. Any solution?
Sorry if my english is not correct. Thank you.
#34
Hello everyone,
I am happy to announce newer version of the image,
https://files.kde.org/neon/images/pinebo...0917-1726/
There are several fixes included,
  • Resuming from sleep is fixed
  • Broken audio after resuming from sleep
  • Bluetooth
  • Palm rejection (Disable "touchpad" while typing)
  • Disable/enable speakers when plugging/unplugging headphones
  • Disable accidental zoom invocation when scrolling in firefox
Errata:
  • Lack of real suspend, I believe this is due to choice of driver we are using, and currently turning lid off puts device to sleep and not suspend like mate image.
  • Sleep inverts the brightness control, after waking up from sleep brightness control are inverted.
If you have any other issues with this build, let me know in comments.
#35
That's great, thanks! Will a sudo apt upgrade install these updates so I don't have to re-configure my machine from scratch?
#36
(09-17-2018, 10:48 PM)bshah Wrote: Hello everyone,
  • Bluetooth
Errata:
Sounds great! Can't wait to try it :-) Am also interested if an upgrade can be done from previous version? Not sure because those palm rejection and ? headphone fixes are the known scripts?
#37
  • Bluetooth
Errata:
Thanks for another awesome release! I reflashed, but would be interested to know if an upgrade is sufficient.
palm rejection and Firefox zoom inhibit are especially useful. Trackpad acts like it's powered by Red Bull! Is suspend supposed to keep the power LED on solid?
If you need anything tested, just let us know!
[ PHP Developer | Pinebook 1G | About me ]
#38
Suspend is still Sleep-mode for now. Anyone with an idea how to put it into real suspend-mode would be absolute fantastic.
For any findings or bug-reports, there is also an issue tracker here:
https://github.com/blue-systems/neon-pin...mix/issues
#39
Added KDE Neon Pinebook 20180917-1726 on Wiki and PINE64 Installer.
#40
The link to the latest img in wiki needs an update to not point to a specific version:
https://files.kde.org/neon/images/pinebo...eredition/
Also adding this info in wiki would be helpful:
Initial Login
   username: live
   password: live
  DietPi OS for Pinebook MichaIng 3 5,334 03-11-2024, 05:02 PM
Last Post: oxoocoffee
  Slarm64 on Pinebook [Slackware Arm - 64 bit] KRT 46 60,719 09-26-2023, 03:18 PM
  Broke pinebook GUI, what to do, fix or install new? acruhl 2 878 07-13-2023, 05:43 PM
Last Post: acruhl
  Orignal PineBook jwp1000 1 678 07-10-2023, 07:44 AM
  Pinebook no longer boots rjtanner 12 3,563 04-13-2023, 01:09 PM
  Stock Debian on original Pinebook moonwalkers 1 3,208 01-29-2022, 10:37 PM
Last Post: cel
  Write image to eMMC - Pinebook 11.6" irongarment 4 3,822 01-04-2022, 09:22 PM
Last Post: irongarment
  E: The repository 'http://pinebook.kde.org.uk bionic Release' no longer has a Release pixelpaperyarn 3 5,218 05-07-2021, 10:20 AM
  pinebook.kde.org.uk no longer has release file?? supermassive 1 3,796 01-20-2021, 11:18 AM
Question Ran apt update on my Pinebook.. ford442 0 2,788 12-25-2020, 04:40 PM
Last Post: ford442
