rockpro64 not more than a rock64 plus two processors?
Can you say the rockpro64 is nothing more than a rock64 computer, the rockpro64 having two more
processors?
Is it possible to quantify in percents how much faster the rockpro64 is?
Thank you.
(08-15-2018, 02:06 PM)heocb Wrote: Can you say the rockpro64 is nothing more than a rock64 computer, the rockpro64 having two more
processors?
Thank you.
I have a ffmpeg test I ran on both the rp64 and r64, the r64 takes just over 15 minutes to complete, and it takes about 5 minutes on the rp64.
processors?
Thank you.
The differences between the RK3328 and the RK3399 is enough to make the jump from the Rock64 to the RockPro64, even if I never manage to make use of the PCIe slot.
(08-15-2018, 04:48 PM)MobileJAD I Agree the rp64 is stupid fast and coming from rpi its a dream Wrote:
processors?
Thank you.
Check side by side Rock64 (RK3328) and RockPro64 (RK3399) and search the internet for reviews/benchmarks.
Advances of RK3399:
  • ~2x faster Cortex-A72 (architecture bigLITTLE for performance and power optimization, 3-way superscalar, 2x-4x more cache)
  • ~2x throughput of memory (64-bit)
  • ~2x-5x faster and newer GPU (Mali-T864 (wiki), OpenGL ES1.1/2.0/3.0/3.1, OpenCL, DX11, Vulkan...)
  • more peripherals (PCIex, more video outputs, camera inputs and other peripherals ...)
I left this community in Aug 2019 due to PINE64 refusal to produce/deliver ROCK64-1G version 3 after more than one year of changing statuses to "planning", "evaluating", "releasing", "availability", "estimated availability" and finally "no schedule" Angry. ROCK64 is dead platform without any advantage. Buy Raspberry PI 4 !
Away
    <snip>
You can add LPDDR4 for the rp64 and LPDDR3 for r64
  irradium (based on crux linux) RockPro64 riscv64, aarch64 mara 1 511 03-25-2024, 12:12 PM
  yocto for RockPro64 Fide 1 731 01-16-2024, 10:01 AM
Last Post: Fide
  Installing Ubuntu Server on RockPro64 deutschlmao 2 2,647 10-29-2023, 04:43 PM
Last Post: brotherj4mes
  Vanilla mainline Debian 11 (Bullseye) on the RockPro64 Pete Tandy 22 17,500 08-16-2023, 01:34 AM
Last Post: varac
  slarm64 (unofficial slackware) ROCKPro64 RK3399 (aarch64) mara 54 83,636 08-11-2023, 11:13 AM
  How to enable CoreSight ETM trace on RockPro64 shpark 0 598 05-21-2023, 11:34 PM
Last Post: shpark
  Rockpro64 Dead on arrival? quixoticgeek 1 964 03-12-2023, 06:55 PM
Last Post: quixoticgeek
  RockPro64 boot questions misterc 3 1,599 01-13-2023, 06:21 PM
Last Post: misterc
  A fix for Bluetooth audio stuttering on the RockPro64 raph 2 1,677 01-03-2023, 06:53 PM
Last Post: raph
  hello i want to drive an edp screen with my rockpro64 hannescam 0 762 10-20-2022, 01:22 PM
Last Post: hannescam
