PCIe-Bus not initialized, no devices detected
I've dumped bootlogs for 3 separate pcie cards with legacy and mainline kernels and attached them to the upstream issue here: https://github.com/rockchip-linux/kernel...-412308351. Hopefully this is useful to someone.
Note: The board won't fully power down when unplugged if you have a serial adapter attached to the UART. I had to pull the serial connection while unplugged or the board wouldn't boot back up afterward.
  PCIE interface power on too late Slark Xiao 0 1,003 11-29-2022, 11:56 PM
Last Post: Slark Xiao
  PCIe gen1 timeout - how to debug tosi 3 4,548 03-10-2022, 05:06 PM
Last Post: db579
  Anyone try an NVIDIA GPU in the PCIe slot? Paraplegic Racehorse 0 1,729 04-15-2021, 11:46 AM
Last Post: Paraplegic Racehorse
  Never ever mix up CPU board connector with 8-pin PCIE connector LMM 0 1,757 02-11-2021, 10:18 AM
Last Post: LMM
  PCIe Armbian and Ayufan for nvme ssd LMM 1 2,661 02-03-2021, 04:38 PM
Last Post: LMM
  fan continously runs on kernel 5.8 but I need to use 5. kernel for PCIe sata card GreyLinux 4 5,680 10-20-2020, 10:52 AM
Last Post: GreyLinux
  PCIe x4 mode - Lane 3 failure acdkyn 1 2,768 04-24-2020, 01:32 PM
Last Post: kuleszdl
  Considering buying and question on the PCIe slot MobileJAD 25 42,820 11-07-2019, 03:10 PM
Last Post: hmuller
  RockPro64 pcie Gpu Davidos 1 3,305 06-09-2019, 02:09 PM
Last Post: guannais
  login to GUI desktop hangs when PCIe SSD is plugged in grimace 3 5,209 04-24-2019, 04:24 PM
Last Post: Luke
