RockPro Wireless+Bluetooth Issue - Linux (ayufan 0.7.8 and previous)
#21
(09-01-2018, 02:34 PM)Bullet64 Wrote: I did not get it to work Wink
I got it to work on this image: http://files.pine64.org/os/ROCKPro64/and...oot.img.xz
on the Rockpro64
No other image the Wi-Fi works yet.
#22
Hi, is there a way to build 0.7.9 with SDIO enabled instead of NVMe / PCIe? I don't want to go back to a less stable older build but I do want to get this SDIO ap6354 working Smile
Also, is there any way to clock the A72s at 2Ghz and the A53s at 1.5Ghz?
Thanks!
#23
(09-14-2018, 06:36 PM)seanp2k Wrote: Hi, is there a way to build 0.7.9 with SDIO enabled instead of NVMe / PCIe? I don't want to go back to a less stable older build but I do want to get this SDIO ap6354 working Smile
Thanks!
For sure you can sort 2.0/1.5GHz by compiling your own kernel - I have, results are here.
Would expect SDIO control (for BT/Wifi instead of, or as well as, PCIe)  is somewhere there as well: haven't seen it but I am not looking as am happy with my NVMe drive.
#24
A little unclear, probably because of incorrect translation of the language,
SDIO is disabled due to a conflict with the PCI-E bus or only because of the support of NVMe drive?
Is it possible to stable operation of the Wifi MODULE on AP6359SA and the PCI-E adapter SATA on the board ROCKPro64 v2.1 ?
(if bluetooth and NVMe drive are not needed)
  irradium (based on crux linux) RockPro64 riscv64, aarch64 mara 1 508 03-25-2024, 12:12 PM
Exclamation Ethernet regression on Linux Kernel 6.5.4? Deathcrow 3 845 09-22-2023, 04:27 AM
Last Post: diederik
  Installing CH431SER on Ayufan 0.9.14: gitlab-ci-linux-build-159 Thisone 4 1,316 07-14-2023, 04:22 AM
Last Post: hunderteins
  GPIO on Ayufan 0.9.14 Build Thisone 7 2,144 04-23-2023, 01:32 PM
Last Post: diederik
  Linux laptop does not detect the board when plugged in via USB soupy 1 4,014 04-13-2023, 03:01 AM
Last Post: Reynold Grady
  A fix for Bluetooth audio stuttering on the RockPro64 raph 2 1,673 01-03-2023, 06:53 PM
Last Post: raph
  RockPro64 linux console video mode callegar 0 887 09-06-2022, 02:32 PM
Last Post: callegar
Brick Maintained Linux booting from eMMC ootoovak 10 8,234 04-30-2022, 03:57 PM
Last Post: TRS-80
  prevent bluetooth from loading (manjaro, no wifi/bt card installed) flounder 0 1,037 02-17-2022, 12:10 PM
Last Post: flounder
  How I Got Fedora Linux to Boot From eMMC (or microSD, for that matter) whitecat23 4 4,296 01-03-2022, 10:32 AM
Last Post: whitecat23
