Successful Bootup
#21
(06-19-2016, 06:56 PM)phloog Wrote: Any news on the edge issue/overscan...looks like this was being discussed two months ago...are we years away from a usual Pine64?
Thanks,
JT
This is not a Pine issue. You have to set the scaling / overscan on your TV correctly. Check here: http://forum.pine64.org/showthread.php?tid=1401
#22
Thanks,
JT
Quite so. It would be nice if the OS auto-detects and adjusts to the screen being used, though. Perhaps something for the future?
#23
Thanks,
JT
Or perhaps adopt a similar solution to what the Raspberry Pi had done in 2012, which was to provide a config file that was visible on the boot partition, which allowed you to configure overscan parameters (amongst other things). Not that I should be mentioning Raspberry Pi on the Pine64 forum! Exclamation  Tongue
#24
Thanks,
JT
No problem mentioning successful solutions to problems Smile
Something similar would be very useful, yes.
  Graphical glitch after bootup kylev2015 2 3,979 04-22-2016, 06:32 AM
