06-19-2020, 03:40 PM
(10-14-2019, 12:50 PM)ayufan Wrote: I'm now working on switching to mainline u-boot for all my distros and to provide exact same functionality. Seems fairly doable
Hello @ayufan. Any updates about this?
u-boot (forks) status
(10-14-2019, 12:50 PM)ayufan Wrote: I'm now working on switching to mainline u-boot for all my distros and to provide exact same functionality. Seems fairly doable Hello @ayufan. Any updates about this?
08-08-2020, 12:05 PM
@XmAz, unfortunately I have not been able to get a mainline U-Boot build working.
08-08-2020, 01:50 PM
08-08-2020, 03:55 PM
False alarm on my side actually... finally set up the serial console and discovered it was a kernel issue, U-Boot 2020.07 and ATF 2.3 work fine here using the open source SPL/TPL.
08-27-2020, 01:44 PM
simonsouth
Quote:I'll write up a lengthier tutorial when I'm done but to start using the mainline version of U-Boot, assuming you have the prerequisites taken care of (the cross-compilation toolchain installed if needed, the ARM Trusted Firmware BL31 built and the CROSS_COMPILE and BL31 environment variables set appropriately), you'll need to .... Thanks, simonsouth, for your primer. Looking forward to the lengthier version if you ever find time. I want to boot a efi_stub enabled kernel, and this 2017 u-boot doesn't know the "efidebug" command, which is necessary, according to these instructions. Your tutorial is encouraging enough to proceed to try and build and upgrade u-boot. |
Rock64 won't boot | luminosity7 | 10 | 4,062 |
03-16-2024, 08:33 AM Last Post: dmitrymyadzelets |
Rock64 doesn't boot | dstallmo | 1 | 323 |
03-16-2024, 08:29 AM Last Post: dmitrymyadzelets |
Boot from SPI first | mjnck | 1 | 1,524 |
02-29-2024, 02:12 PM Last Post: reukiodo |
ROCK64 v3 can it boot from USB? | Tsagualsa | 4 | 2,074 |
11-29-2022, 11:31 AM Last Post: Macgyver |
Rock64 u-boot for eMMC Build Error | mexicanflyer | 0 | 1,048 |
09-18-2022, 02:29 PM Last Post: mexicanflyer |
boot hdd usb3 | philipe | 1 | 2,640 |
01-27-2021, 02:12 PM Last Post: tllim |
Sent support order status , no responses | RockPro64Newbie | 3 | 6,019 |
01-19-2021, 12:09 PM Last Post: mathygreen |
Libreelec Rock64 - 4GB no boot | spiker15 | 3 | 4,552 |
11-02-2020, 12:36 AM Last Post: wilsonYan |
Rock64 - boot | helpmerock | 2 | 3,530 |
10-08-2020, 01:29 PM Last Post: helpmerock |
No boot up after power on | Whoopsadaisy | 4 | 5,643 |
09-26-2020, 05:14 PM Last Post: simonsouth |
