Office System 24/7
Hi everybody!
This is my first experience with a SBC.
Basically, i need something i could keep running 24/7.
It would need to do browsing activity with some medium flash player usage.
It would also need to have as low as possible power consumption and noise making.
After looking for some possible PC builds, i've tried to look at SBC. I was very skeptical at the beginning because i only knew raspberry and its resources weren't enough for me.
Then i found Rock64.
Now, basically the question is, given that 4GB ram should be more than enough for my use case, would the CPU keep it up?
In other words: is rock64 what i am looking for or should i look further?
(07-04-2018, 06:07 PM)joe Wrote: Any arm cpu not support flash player , and google said flash player not safe now
Still, unluckly, i'm forced to use it for work.
Is there any workaround like Kiosk for Raspberry?
Could this work? http://hwswbits.blogspot.com/2013/04/fla...x-arm.html
  Just received Pinephone - system crashes Zebulon Walton 12 13,425 11-13-2020, 05:45 PM
  No top system menu maxchess 3 4,904 06-14-2019, 07:11 AM
Last Post: maxchess
  qemu-system-aarch64 11b2p508 1 3,313 07-19-2018, 10:26 PM
Last Post: shizzle411
  Robot Operating System (ROS) jesse1234 8 10,992 02-28-2017, 08:33 PM
Last Post: dkryder
  Reset system mcrognale 2 4,448 10-16-2016, 04:49 PM
Last Post: mcrognale
  MS Office sh2 1 4,271 12-11-2015, 12:08 AM
