If you've messed up your eMMC Card - Solved
Using SD Formatter have you set Size Adjustment to On
Having decided that I quite like Armbian, in my attempts to find a good desktop OS, I also decided to put it on my eMMC card, which took me straight back to the problem I had before. The eMMC card appears as a 32mb card to both Xubuntu and Win10.
I tried both SD Formatter and DISKPART, but neither would register a card above 32mb neither would they format it or ‘clean’ it. Gparted would neither delete this 32mb partition nor create a new partition table, so I was stumped.
Once again I flashed Aufan’s image to an SD Card and using the pin shortening method, booted into bionic-lxde, with the eMMC installed onto the Rock64 board. It seems that the pin shorting method will only work on a newly flashed image. Gparted saw all the partitions on the eMMC so I deleted them, and created a new 64GB ext4 partition. Back to Xubuntu and Win10 for flashing Armbian onto the eMMC. Neither OS would see anything other than a 32mb partiton, despite all that I had just carried out.
I tried to go back and use the
/usr/local/bin/rock64_reset_emmc.sh
emmc reset trick, but suddenly I could no longer boot into the SD Card with the eMMC installed, no matter what distro I used. The two pin shorting out trick no longer worked, for some reason. I tried deleting the SP1 flash, but this made no difference either.
If I could have gone to a local shop to buy an eMMC card, I would have done so.
If anyone else ends up in this predicament, I don’t know what they should do. I was in the good position of owning an Odroid XU4 so using the eMMC recovery utility,
Odroid eMMC recovery
I installed Odroid Android. After doing this and running it on the Odroid, I was able to use Etcher and load Armbian onto my eMMC Card. It is booting and running fine.
All this took me most of the day. Surely there is a better way. isn’t there, to recover an eMMC Card? The Rock 64 4GB has so much promise as a desktop computer, but maybe it is just early days, or is it just me that struggles?
PinePhone Beta 2GB/16GB Postmarket OS v23.06.1 Phosh 0.30.0 (not in use)
PineTab2 Arch Danctnix 6.4.2
  Buildroot 2021.08 not booting from SD card jimmy 1 2,021 11-08-2021, 02:25 AM
Last Post: hunderteins
  Debian (Vanilla) on Rock64 and eMMC - how ? as365n4 4 5,279 09-21-2020, 04:33 AM
Last Post: as365n4
  Display limited to 800x600 [SOLVED] Averell 16 18,718 06-05-2020, 11:07 PM
Last Post: ab1jx
  Nextcloudpi SD card fills up. default_user8 13 16,756 12-04-2019, 01:30 PM
Last Post: Rocklobster
Question [SOLVED] Alpine Linux won't boot rock7 1 5,775 10-22-2019, 04:30 PM
Last Post: rock7
  Clone the SD to eMMC tagyro 1 3,393 02-06-2019, 06:55 AM
Last Post: evilbunny
  Repair corrupt root filesystem on emmc David82 1 3,751 01-31-2019, 01:11 PM
Last Post: Tozzi
  Migrate Linux from microSD to onboard eMMC elik745i 7 9,865 11-03-2018, 08:23 AM
  [solved] Unable to start X Osiander 8 11,460 10-03-2018, 03:54 AM
Last Post: jovval
  Tutorial How to write a image in the eMMc card without USB adaptor or serial cable gedas07 2 3,831 08-29-2018, 10:08 AM
Last Post: gedas07
