Trouble with my pinebook
My pinebook is not booting anymore. The screen remains dark after more than 10 trials to power off/on with the upper right button.
I think it is because I'm a pine64 and I installed updates for rock64 from Ayudan, and i should not have.
I also entered a command to reboot but it was set on 1 and I'm scared that it might be trying to boot on windows.
Please help me...
Kenzucky
Here is what I did in the Terminal :
$ wget https://github.com/ayufan-rock64/linux-b..._arm64.deb
$ dpkg -i linux-image-4.13.0-rc1-rockchip-ayufan-93-ga1d4fc4_0.5.5_arm64.deb
$ sudo grub-reboot 1 ; reboot
Yes, that likely broke your installation. The Rock64 uses a diffrent SOC than the Pinebook (which uses A64). What were you trying to do ?
I was trying to install Grub to load Mint basically but I lost patience and now it is a mess.
More in details, I wanted to configure my pinebook to initiate the installation of Grub from a specific location.
But I did not know where to start. I discovered too late that it had no BIOS nor UEFI.
The actions I took were :
- attempt to partition an SD card to boot on Grub( partially failed)
- verify whether I had Synaptics, apturl or else (success)
- verify if Grub was installed (not installed)
- change from apturl to synaptic (success)
- verify the distribution (but I suspect the command has been forged to pretend it was Kali Linux)
- download boot-repair and Grub
- try to reboot holding shift/escape (fail)
- enter the commands that broke my installation
@Luke
Can you tell me what is broken exactly ? Is it the software ? Can I buy a new SoC to fix the problem ?
This is an ARM laptop, so it uses uboot. You also won't be able to use a x86 distro (Linux Mint) unless you use rootsfs to build an image yourself (or there is an ARM64 install [edit] for the Pinebook - and there isn't). There isn't a need to buy anything, hardware isn't broken.
Regardless, perhaps there is a way to save your current installation - but you'd have to wait for someone more knowladgable to show up and tell you how (probably need to replace some part of the kernel).
If you don't care too much about your current installation, then all you have to do is flash one of the many different available images (I suggest either ayufan's xenial OR armbian).
Yes but it does not boot, I can't replace a part of the kernel.
I have to learn C and partitioning...on my Windows PC.
Thank you for your precious help.
(06-29-2018, 04:22 PM)Kenzucky Wrote: Yes but it does not boot, I can't replace a part of the kernel.
But you will be able to boot from a microSD card if you can download and write it on another machine (SD boots before eMMC on pinebook).
You may be able to 'simply' boot from a microSD with the same or similar image to which you had on the pinebooks eMMC, and once it's booted, copy the kernel and Image files across from the microSD /boot partition to the eMMC /boot partition.
I strongly doubt any hardware is damaged, and it should be possible to recover the system by replacing that kernel. However, I don't know what other problems that might arise due to broken package repo etc is another problems, etc. That's for someone else more knowledgeable to comment on Wink
It does not boot, but thanks for trying to help me.
  Pinebook Pro vs Pinetab2 Lotech 0 289 02-13-2024, 08:57 PM
Last Post: Lotech
  Maximum size of boot MicroSD for RockPro64 and Pinebook Pro commiecam 0 1,701 08-07-2022, 10:47 AM
Last Post: commiecam
  Please Help: Bricked Pinebook Pro with Keyboard Update dumbguywhobrokehiscomputer 3 4,023 07-14-2021, 02:49 PM
  Java on Manjaro ARM Pinebook Pro gulagpyromaniac 3 3,888 05-25-2021, 11:05 AM
  Setup My Pinebook 64 and Lost Password jersdayoff 5 5,855 05-01-2021, 10:29 PM
  How to boot from SD card on pinebook pro linux123 3 6,084 12-02-2020, 10:29 AM
Last Post: linux123
  Pinebook Pro- configuration aborts setting keyboard layout scroall 10 12,297 10-30-2020, 11:58 AM
Last Post: scroall
  Changing locale on Pinebook Pro Perl6_user 5 7,092 09-16-2020, 05:13 PM
Last Post: guava
Big Grin New to Pinebook Pro SanjevR 5 9,026 06-07-2020, 07:35 AM
Last Post: spikerguy
  WiFi issues Pinebook Pro sunnystormy 6 9,048 05-28-2020, 05:44 PM
Last Post: Luke
