PSU broken
My pinebook (which I use on a daily basis) seems to have stopped charging. I guess the power supply died. The is no green light as ther used to be when the book charged.
I know it is a 5V adapter 3A, but can somebody tell me if the core pin is + or -? Then I can look around for a replacement adapter here in NL
Thanks for any reply,
Erik
(06-05-2018, 09:51 AM)Erik Wrote: I know it is a 5V adapter 3A, but can somebody tell me if the core pin is + or -? Then I can look around for a replacement adapter here in NL
Centre +ve
Type H, 3.5mm OD/1.35mm ID
It shouldn't be too hard get a generic replacement locally... the leads seem readily available on eBay and are cheap, so it's a common enough size. Good luck!
  Broken display connector Mick 3 377 12-13-2023, 01:47 PM
  Touchpad broken? rookieone 4 5,691 04-05-2020, 05:53 AM
Last Post: rookieone
  keyboard broken? Erik 0 1,877 05-20-2019, 02:52 AM
Last Post: Erik
  broken keyboard -> transplant all organs into an thinkpad? stereo 1 2,770 05-19-2018, 03:25 PM
Last Post: stereo
