Raspberry Pi OneNineDesign Case "Mod"
I've bought a quite cheap (2.36 €) version of this case on aliexpress for tinkering, don't know if it's a copy or not, case looks very good and nicely polished.
In order to put a Rock64 into it, some "adjustments" were needed, mostly for the board to fit inside, but also for power and A/V jack which are weirdly shifted a bit on the right when you put the board in front of you.
here [click to show the album] are some pics of the "rough surgery" the case got.
There are still some work to do to get access to switches near the recovery one and make a hole for the IR receiver just in case.
I first use pliers to remove the big plastic part inside, then a modelling knife and a grinding tool to got a smooth finish.
(If you have any trouble accessing the album, please let me know, I upload pics on imgBB and set the permission in order anyone clicking on the link can show it)
on my side i bought this cheap case with its accesories.
I just had to do a little modification for the power supply, and 2 little holes for the switches.
regards
Most of the modern Raspberry Pi case works on ROCK64. The only part taht may need to modify or adjust is the power supply jack hole.
  Case for the rock64 that supports the POE hat. o1CRiMSON1o 0 608 03-21-2023, 03:48 PM
Last Post: o1CRiMSON1o
  3D-Printable Button Pegs for the ROCK64 Aluminium Case CounterPillow 2 3,465 08-04-2022, 01:31 AM
Last Post: Vicky Weimann PhD
Smile wooden case for ROCK64 killor 13 16,403 03-04-2022, 06:56 AM
Last Post: killor
  Assembling the premium aluminum case mlefevre 14 15,597 07-07-2021, 05:50 AM
Last Post: Rocklobster
Heart Best quick/easy way to control case fan speed? idillicah 4 5,946 06-24-2021, 09:14 AM
Last Post: CounterPillow
  What thermal compound will fit better to the aluminum case? m.bakhterev 1 2,945 01-26-2020, 12:56 PM
Last Post: clach04
Information Brushless Fan (5v) for Rock64 Clear Case Soft PWM Drive 2N2222 MarkHaysHarris777 7 15,997 07-09-2019, 06:15 AM
Last Post: merwone
  Rock64's temperature while being in aluminium case _zernok 3 5,858 06-23-2019, 08:00 AM
Last Post: rasputin
  Fitting Rockpro64 inside Pinebook case made2hack 2 3,725 02-20-2019, 01:27 AM
Last Post: made2hack
  Is recommended to buy the case? enreador 1 2,849 05-03-2018, 03:55 PM
Last Post: evilbunny
