How do you like the case?
Love it
50.00%
18
Like it
30.56%
11
Its not for me
19.44%
7
36 vote(s)
RockPro64 Case 2x3.5" HDDs and 2x2.5 HDDs
Hi Guys, does the case fit the 20mm or 30mm heat sink, with or without fan on top of it? Also, is there a way to have 4 HDD/SSD since the PCI-e to dual sata controller supports only 2? Thanks.
so some thoughts on this. an alternate case top that has mounting for the touchscreen. the touchscreen would mount on top of the hdd frame and the case top would have a hole to let it be exposed.
(07-23-2018, 03:24 PM)Firesped Wrote: so some thoughts on this. an alternate case top that has mounting for the touchscreen. the touchscreen would mount on top of the hdd frame and the case top would have a hole to let it be exposed.
Agreed that would be pretty cool. Although, I'd prefer a much smaller screen for htop or similar rather than the 7" screen (if that would even fit?)
For the 80mm fan in the back, would you need a PWM fan?
For example:
https://www.bequiet.com/en/casefans/258
versus:
https://www.bequiet.com/en/casefans/324
I am not sure if they have different connectors? And can a PWM fan still work (at fixed speed?) if there's no support in software (yet)?
Well my Rockpro case and accessories arrived today!!!
It is incredibly well made, could survive a truck driving over it.
It is well finished and my Rockpro board fits in it exactly, the cutouts are just right in the correct places.
Very good design.
However all I am waiting for is a reliable Linux operating system  to work with it,  or perhaps as I keep saying, a reliable board to run the operating system on.
I have posted a new  thread in hardware about the flakeness of the module.
cheers
P
Here's some photos of my build of the RockPro64 in the case Smile
I've a case fan, it has a 4-pin connector though, so I am still have to see how I can connect this to the rockpro64 board...
So I did not add the fan into the case yet, but how it is now, it will only just fit! Wink
RockPro64 case https://imgur.com/a/BltKsrG
[Image: 9BTftVx.jpg]
[Image: 419JSxH.jpg]
[Image: lhgGI3g.jpg]
[Image: zSnL8NY.jpg]
[Image: rQ0keMj.jpg]
[Image: wvHosW4.jpg]
[Image: vn9m1fq.jpg]
[Image: 81ElkzO.jpg]
Hi Luke,
The ROCKPro64 case looks great and glad to see it is now available in the store. I think it will suit my needs quite nicely as a Docker host for backups and other projects!
One thing I think would be really useful for more hardware inexperienced people like myself is if there was a "shopping list" somewhere, here or in the store, so I would know exactly what I need to buy to get it all going. Either a list of links to each item needed (or if you have input into the shop have a "starter-kit" listed).
I think the shopping list could assume that the user has the HDs as Pine64 does not sell those but links to everything else that you need to buy to get this going by scratch would be super useful so I don't buy the wrong things or miss buying things that are important.
Cheers!  Smile
(07-25-2018, 12:04 AM)rookieone Wrote: For the 80mm fan in the back, would you need a PWM fan?
For example:
versus:
Could you figure out sth regarding pwm fans? I will check the schematic later, it mighr be possible to use the pwm for the case fan.
Regarding the fan size, OP says it's a 120mm fan but the drawings point to a 80mm one. Could you be more specific in that aspect, maybe update product description too?
#19
For example:
versus:
80mm one
#20
Hey Rookieone, thanks for the post Smile Also, nicely routed cables.
  Installing Wifi drive for the RockPro64 John45595 0 307 02-10-2024, 11:32 PM
Last Post: John45595
Wink You don't sell case and fan for "ROCKPro64 4GB Single Board Computer"? Clea 1 755 09-17-2023, 12:00 AM
  Want to check maximum toggle speed in Rockpro64 board. kundanjha 0 683 08-14-2023, 07:55 AM
Last Post: kundanjha
  Unable to boot Armbian on new RockPro64 mooseball 5 4,247 07-14-2023, 08:59 AM
Last Post: rockjonn
  Hardware fix for software sound problem on Rockpro64 Ricks Rockpro 0 888 04-06-2023, 03:59 PM
Last Post: Ricks Rockpro
  No sound on Rockpro64 with OpenWrt Patrice 1 1,323 04-06-2023, 02:46 PM
  Cant get rockpro64 working brasilikum 3 1,823 03-19-2023, 06:22 AM
Last Post: runyor
  RockPro64 Stopped working WarpLover 5 2,650 02-06-2023, 10:10 AM
Last Post: diizzy
Lightbulb ROCKPro64 + SSD case model for 3D print Spater 0 1,019 01-27-2023, 07:43 PM
Last Post: Spater
  RockPro64 and Neon rapier1 2 1,788 10-21-2022, 07:44 AM
Last Post: rapier1
