NetBSD for Pine A64(+)
NetBSD is available for Pine A64(+). Images are available in both 32 and 64bit variations.
Download here
(05-24-2018, 10:58 PM)Luke Wrote: NetBSD is available for Pine A64(+). Images are available in both 32 and 64bit variations.
Download here
From the looks of the blog post they did in Nov '17 on the state of Allwinner Soc support, it looks like quite a few things should be working... particularly the GbE ethernet.
However, since they don't have SDIO Wifi working, anyone who needs the custom 'integrated' wifi module will want to avoid this for now, as it won't work. That and the fact that 3 of the four processor cores are switched off! They have certainly put a lot of effort into this though, and from the sounds of it if a features is supported it works, and works well.
From their writeup about the pinebook image:
Quote:The A64 is a quad core design. NetBSD's aarch64 pmap does not yet support SMP, so three cores are disabled for now.
oh! thanks for pointing all this out, I only saw the announcement - didn't look in to the specifics.
the SMP problem has been solved for quite a while now (well over a year).
  Pine A64 does only boot with Android 5.1 Dude 6 2,035 07-03-2022, 02:18 PM
Last Post: Dude
  Pine A64+ vs LCD do not boot DDS 3 4,658 02-23-2021, 05:33 PM
Last Post: thedu
  Autodetect if Pine unit is a Pine A64+ or PineA64-LTS pkfpeters 1 2,395 02-09-2021, 12:17 AM
  Pine 64 | 2GB x2 & Acrylic Cases x2 for Sale | Canada - GTA ViperVi 1 3,657 01-18-2021, 03:45 PM
Last Post: squidius
  sd format?for pine 64 angegardien 3 6,143 12-06-2020, 03:53 PM
Last Post: junkyj753
  Node Red on the Pine DonFL 0 2,301 12-16-2019, 04:21 PM
Last Post: DonFL
Photo Pine A64+ from Kick starter running Pi-Hole netHolio 0 2,683 12-02-2019, 09:36 PM
Last Post: netHolio
  Can anyone run Boinc on Pine models? MarijusR 6 7,768 09-11-2019, 06:41 AM
Last Post: letarg
  There is a usable distro for Pine A64? polv89 6 8,850 06-09-2019, 03:32 PM
Last Post: dkebler
  Pine A64 stuck in boot process joey 1 2,830 05-28-2019, 09:07 PM
Last Post: joey
