canNOT boot after a normal apt upgrade
The latest upgrade push kernel 4.4.126 and crash Rock64 when reboot.
By using serial cable, there is a short moment that user can select to boot from the previous kernel (the lovely stable 4.4.77).  So, be claim, everything is still there, I believe.
Unfortunately, seems that there is no hope for pure ssh remote control boxes.
Anyway, any elite kind enough to post a know-how on how to change the default boot order specifically for Rock64 on this forum.
Thank you
p.s.  if possible, also a know-how to prevent the kernel from being updated automatically.
the 1st know-how
$ sudo vi /boot/efi/extlinux/extlinux.conf
change the 2nd line from
default kernel-latest
to
default kernel-previous
2nd know-how
tested work on a fresh burnt sdcard with 4.4.77
rock64@rock64:~$ sudo apt-cache showpkg linux-image
Package: linux-image
Versions:
Reverse Depends:
  firmware-crystalhd,linux-image
Dependencies:
Provides:
Reverse Provides:
linux-image-4.4.77-rockchip-ayufan-136 0.5.15 (= )
linux-image-4.4.77-rockchip-ayufan-118 0.5.10 (= )
linux-image-4.4.77-rockchip-ayufan-104 0.5.9 (= )
linux-image-4.4.77-rockchip-ayufan-102 0.5.8 (= )
linux-image-4.4.71-rockchip-ayufan-77 0.4.12 (= )
linux-image-4.4.70-rockchip-ayufan-85 0.4.17 (= )
linux-image-4.4.70-rockchip-ayufan-83 0.4.16 (= )
linux-image-4.4.70-rockchip-ayufan-66 0.4.3 (= )
linux-image-4.4.70-rockchip-ayufan-62 0.3.7 (= )
linux-image-4.4.70-rockchip-ayufan-57 0.3.4 (= )
linux-image-4.4.70-rockchip-ayufan-55 0.3.3 (= )
linux-image-4.4.70-rockchip-ayufan-54 0.3.2 (= )
linux-image-4.4.70-ayufan-29 0.2.1 (= )
linux-image-4.4.70-ayufan-28 0.2.0 (= )
linux-image-4.4.126-rockchip-ayufan-227 0.6.41 (= )
linux-image-4.4.126-rockchip-ayufan-226 0.6.40 (= )
rock64@rock64:~$ sudo apt-mark hold linux-image-4.4.126-rockchip-ayufan-227 linux-image-4.4.126-rock
chip-ayufan-226
linux-image-4.4.126-rockchip-ayufan-227 set on hold.
linux-image-4.4.126-rockchip-ayufan-226 set on hold.
Run "apt upgrade" and you'll see that 4.4.126 is gone.
However, some people said this method induce instability due to rapid changes on all packages. So, you are warned.
I can confirm that with the latest kernel update the system hangs at boot.
Getting back to previous kernel it runs again without issues.
That's a big issue though
On the other hand the hold command you wrote did not worked for me.
I set on hold the packages
linux-rock64
linux-rock64-package
at version 0.5.15
that avoid my kernel to be upgraded
I'm using the Xenial minimal image on SD
  Rock64 won't boot dstallmo 0 325 12-27-2023, 10:34 AM
Last Post: dstallmo
  arch rock64 does not boot nemnob 0 584 07-09-2023, 03:28 AM
Last Post: nemnob
  Disabling last mount time check on boot acwest 0 615 03-03-2023, 09:24 PM
Last Post: acwest
  Swap/Upgrade Storage Device? r00t3d 0 679 08-17-2022, 06:11 AM
Last Post: r00t3d
  Rock64 Rev3 doesn't boot and leds blinking fast dishins 6 7,739 06-30-2022, 06:28 PM
Last Post: rookie_267
  my rock64 can't boot rookie_267 0 1,040 06-27-2022, 06:52 PM
  Setting a MAC on Rock64 U-Boot kiriakos 2 3,553 03-23-2021, 04:51 AM
Last Post: kiriakos
  Boot from USB 3.0 with hub Turbo 0 2,096 12-20-2020, 02:24 PM
Last Post: Turbo
  Unable to boot armbian fchazal 2 3,845 05-19-2020, 06:43 PM
Last Post: Rocklobster
  Rock64s will not boot any OS camosoul 2 3,418 05-19-2020, 06:38 PM
