ROCKPRO64 PCI-E SATA is low price and low power best to choose wipe your hard disk
Wink
If your company or personal not use your old hard disk , but the hard disk data include have your privacy data from hard disk e.g ( Your medical treatment information , ID CARD Number , VISA CARD , PASSWORD   ), this time you need to wipe your hard disk by the US LAW (HIPAA) .
This is very basic level to clear up your include privacy data.
I think most people know delete file is not really deleted , so this need to use Rrockpro64  help.
For the new generation HardDisk over 2TB , you need is time time time and more time and electricity  to wipe your hard disk.
Yes , you can say physical destroy is very fast , easy and safe , but physical destroy tool very expensive .
I reseach some have hardware they just to run software wipe your hard disk.
1. http://www.mejw.com.tw/  TP100-I around USD $456   ( Support  4TB )
2. http://www.killdisk.com/killdesk.htm USD $1999   ( Support more than 4TB in size )
Debian arm64 , armhf open source software have ( Scrub , Nwipe  ) can wipe your hard disk.
( Note: This two software without warranty and any certification  ( e.g HIPAA, ISO27001/27002) ,  no guarantee your data is completely sanitized across the entire drive , but the same have wipe algorithm .)
At least recovery software can't find it privacy data
1. Scrub  ( wipe algorithm )
https://github.com/chaos/scrub
[Image: A4RIenN.png]
2. Nwipe  (Based on Dban )
https://github.com/martijnvanbrummelen/nwipe
[Image: 3Uf44fc.png]
Other:  Open source Dban need your x86 , x86-64 pc around 300 w Power to wipe your harddisk , very waste your money  .
Rockpro64 you have 1 usb3.0 , 1 PCI-E support 2  SATA port
If I am wrong please correct my content , thank !
1. Use Pine64 Running Ubuntu 16.04 Web Server ( LAMP )
2. Use Pine64 Running Official Android 6  for Media player
3. Use Pine64 Running Volumio Digital Audio Player
why not just use dd?
(05-13-2018, 03:51 PM)dkryder Wrote: why not just use dd?
Why not just use my ryobi cordless drill and a 10mm metal bit.. it's much faster! Tongue
only dd  random to wipe your hard disk is not safe .   So why Dban was many people downloads: 14,121 This Week? why people need this ?
https://sourceforge.net/projects/dban/
And please search  NIST.SP.800-88r1.pdf  page 40 ( ATA Hard Disk Drives This includePATA, SATA, eSATA, etc ) for hard disk from google , this is usa security suggest to clear your hard disk  .
Yes you can , but your hard disk can't use again .............  2TB........you really want to waste your hard disk ?
what is unsafe about using dd to
dd if=/dev/zero of=/dev/sdX or something similar?
(05-14-2018, 02:25 AM)dkryder Wrote: what is unsafe about using dd to
To wipe properly you need to do a few wipes with random data...
How about the  0 x FF ?
Good wipe for hard disk is 0 , 1  , random  .
Big Grin
All jokes aside, this could indeed be a niche market for the rock64pro... wonder how long it will take before someone makes some sort of rock64pro-based hard drive erasing product with easy to use touchscreen for say US$129? Smile [ be warned, Joe mentioned the idea first, and I just turned it into a product, so we want royalties if someone does do that!  Angel  ] Big Grin Big Grin
(05-14-2018, 10:51 PM)pfeerick Wrote: All jokes aside, this could indeed be a niche market for the rock64pro... wonder how long it will take before someone makes some sort of rock64pro-based hard drive erasing product with easy to use touchscreen for say US$129? Smile [ be warned, Joe mentioned the idea first, and I just turned it into a product, so we want royalties if someone does do that!  Angel  ] Big Grin Big Grin
Yes this is  jokes , but  this is i saw at least 4 company to sales hardware wipe tool ,  very expensive.
basically this is wipe your hard disk  to protection your information just is level one.
level two is hard disk demagnetize , level three is physical destroy.
I think for home user use wipe software is enough , for company  wipe software is protection you send some where
e.g repair or destroy your hard disk prevent some people easily to recovery your information.
  Installing Wifi drive for the RockPro64 John45595 0 309 02-10-2024, 11:32 PM
Last Post: John45595
  enble boot after power loss/restore dkebler 18 9,429 12-04-2023, 12:14 PM
Last Post: ok38
  Mainline U-Boot with SPI, NVMe and SATA boot support sigmaris 108 119,496 09-25-2023, 12:46 AM
Last Post: ChriChri
Wink You don't sell case and fan for "ROCKPro64 4GB Single Board Computer"? Clea 1 757 09-17-2023, 12:00 AM
  Want to check maximum toggle speed in Rockpro64 board. kundanjha 0 683 08-14-2023, 07:55 AM
Last Post: kundanjha
  Unable to boot Armbian on new RockPro64 mooseball 5 4,257 07-14-2023, 08:59 AM
Last Post: rockjonn
  Hardware fix for software sound problem on Rockpro64 Ricks Rockpro 0 891 04-06-2023, 03:59 PM
Last Post: Ricks Rockpro
  No sound on Rockpro64 with OpenWrt Patrice 1 1,326 04-06-2023, 02:46 PM
  Cant get rockpro64 working brasilikum 3 1,826 03-19-2023, 06:22 AM
Last Post: runyor
  RockPro64 Stopped working WarpLover 5 2,654 02-06-2023, 10:10 AM
Last Post: diizzy
