LPDDR4 Benchmarks
I'm interested in what benchmarks changed with the move from LPDDR3 to LPDDR4.
To start with, specifically what is the output of
cryptsetup benchmark
with LPDDR4?
Once there is a Linux image available I'll post benchmarks.
Currently LPDDR4 set to PC-1600 parameter and will push up in near future. This means expects as PC-1600 type of performance result first.
Just for fun I used
termux-ubuntu
on my phone but it only got part way ;
# Tests are approximate using memory only (no storage IO).
PBKDF2-sha1       859488 iterations per second for 256-bit key
PBKDF2-sha256    1699474 iterations per second for 256-bit key
PBKDF2-sha512     497426 iterations per second for 256-bit key
PBKDF2-ripemd160  447344 iterations per second for 256-bit key
PBKDF2-whirlpool  168907 iterations per second for 256-bit key
argon2i       4 iterations, 664468 memory, 4 parallel threads (CPUs) for 256-bit key (requested 2000 ms time)
argon2id      4 iterations, 726194 memory, 4 parallel threads (CPUs) for 256-bit key (requested 2000 ms time)
Required kernel crypto interface not available.
Ensure you have algif_skcipher kernel module loaded.
other rk3399 RAM benchmarks here.
On the bionic-containers-rockpro64-0.6.44-239-arm64 image for the ROCKPro64, I got this:
rock64@rockpro64:~$ cryptsetup benchmark
PBKDF2-sha1       774428 iterations per second for 256-bit key
PBKDF2-sha256    1470653 iterations per second for 256-bit key
PBKDF2-sha512     489988 iterations per second for 256-bit key
PBKDF2-ripemd160  378274 iterations per second for 256-bit key
PBKDF2-whirlpool  172010 iterations per second for 256-bit key
argon2i       4 iterations, 386620 memory, 4 parallel threads (CPUs) for 256-bit key (requested 2000 ms time)
argon2id      4 iterations, 369429 memory, 4 parallel threads (CPUs) for 256-bit key (requested 2000 ms time)
#     Algorithm | Key |  Encryption |  Decryption
       aes-cbc   128b   616.2 MiB/s   832.0 MiB/s
   serpent-cbc   128b           N/A           N/A
   twofish-cbc   128b    80.4 MiB/s    82.4 MiB/s
       aes-cbc   256b   529.3 MiB/s   747.7 MiB/s
   serpent-cbc   256b           N/A           N/A
   twofish-cbc   256b    80.6 MiB/s    82.1 MiB/s
       aes-xts   256b   681.4 MiB/s   680.5 MiB/s
   serpent-xts   256b           N/A           N/A
   twofish-xts   256b           N/A           N/A
       aes-xts   512b   620.1 MiB/s   619.6 MiB/s
   serpent-xts   512b           N/A           N/A
   twofish-xts   512b           N/A           N/A
And just for comparison, here is the same benchmark on the rock64 (same image, but rock64 version):
rock64@rock64:~$ cryptsetup benchmark
PBKDF2-sha1       277989 iterations per second for 256-bit key
PBKDF2-sha256     495546 iterations per second for 256-bit key
PBKDF2-sha512     202584 iterations per second for 256-bit key
PBKDF2-ripemd160  160824 iterations per second for 256-bit key
PBKDF2-whirlpool   71157 iterations per second for 256-bit key
argon2i       4 iterations, 284387 memory, 4 parallel threads (CPUs) for 256-bit key (requested 2000 ms time)
argon2id      4 iterations, 299706 memory, 4 parallel threads (CPUs) for 256-bit key (requested 2000 ms time)
        aes-cbc   128b   348.7 MiB/s   433.2 MiB/s
    twofish-cbc   128b    29.7 MiB/s    30.6 MiB/s
        aes-cbc   256b   300.6 MiB/s   394.8 MiB/s
    twofish-cbc   256b    29.9 MiB/s    30.7 MiB/s
        aes-xts   256b   385.2 MiB/s   385.6 MiB/s
        aes-xts   512b   356.9 MiB/s   356.1 MiB/s
Thanks pfeerick, looks like The LPDDR4-1600 did not help that particular benchmark which is reasonable as it's likely SOC bound. Odd that N1 was slightly faster 620.1 vs 655.6, but likely just some minor software diffrence...
what kernel was that on?
uname -r
(06-03-2018, 08:52 PM)elatllat Wrote: Thanks pfeerick, looks like The LPDDR4-1600 did not help that particular benchmark which is reasonable as it's likely SOC bound. Odd that N1 was slightly faster 620.1 vs 655.6, but likely just some minor software diffrence...
uname -r
Not sure, I'll check in the morning. It was the stock for that image though. It's still early days for the images also, so there is still room for improvement.
ROCKPro64 w/ 4GB RAM, bionic-containers-rockpro64-0.6.51-253-arm64.img.xz, kernel 4.4.126-rockchip-ayufan-253
This will likely be a little slower than the previous results where CPU frequency counts - the 0.6.44 was clocked slightly higher with a custom op basically clocking the big CPUs at 2Ghz, and they have since been taken back down to 1.8Ghz.
pfeerick@rockpro64:~$ cryptsetup benchmark
PBKDF2-sha1       713317 iterations per second for 256-bit key
PBKDF2-sha256    1342606 iterations per second for 256-bit key
PBKDF2-sha512     436906 iterations per second for 256-bit key
PBKDF2-ripemd160  329740 iterations per second for 256-bit key
PBKDF2-whirlpool  148945 iterations per second for 256-bit key
argon2i       4 iterations, 355026 memory, 4 parallel threads (CPUs) for 256-bit key (requested 2000 ms time)
argon2id      4 iterations, 354864 memory, 4 parallel threads (CPUs) for 256-bit key (requested 2000 ms time)
       aes-cbc   128b   532.3 MiB/s   710.2 MiB/s
   twofish-cbc   128b    70.1 MiB/s    74.0 MiB/s
       aes-cbc   256b   456.4 MiB/s   632.9 MiB/s
   twofish-cbc   256b    72.3 MiB/s    73.7 MiB/s
       aes-xts   256b   580.2 MiB/s   581.8 MiB/s
       aes-xts   512b   537.8 MiB/s   538.1 MiB/s
