Flashing rockchip 'update' images on Linux
If you're using Linux on your PC then flashing Android images to the Rock64 (other than the RAW dd images) is a bit tricky.
I came across a utility for Linux that makes the process nice and easy, allowing you to flash 'update' images directly to eMMC.
The software is called upgrade_tool and can be downloaded from here
You can read about it and its different functions here
In short, after downloading and extracting the contents of the archive, navigate in terminal to the extracted utility and flash the update.img using the following command:
sudo ./upgrade_tool uf /path/to/update.img
[edit] I forgot to add; you need to force the board into recovery mode first and it has to be connected to your Linux PC using an A-to-A USB cable.
  Android Images (ROCK64) pineadmin 73 168,429 05-04-2021, 01:58 AM
Last Post: zet_lab
  broken android microsd images jbach50 1 3,498 01-16-2021, 09:57 PM
Last Post: jimsurvak
  Error! Android Rockchip tools method BowerR64 0 2,574 09-18-2020, 08:12 PM
Last Post: BowerR64
  Cannot flash android 9 rockchip tool totalgaara 2 4,714 09-09-2020, 07:05 AM
Last Post: BowerR64
Exclamation Flashing Libre Computer ROC-RK3328-CC rom to ROCK64 fender90 0 2,519 11-26-2018, 08:08 AM
Last Post: fender90
  Flashing H96 Max firmware with Ayufan's kernel fender90 6 9,828 08-27-2018, 07:41 AM
Last Post: fender90
  Differences between Android and Android TV images 1n9i9c7om 8 10,915 04-16-2018, 06:25 AM
Last Post: noob
  Flashing problems USB -> eMMC adaptor pinerock 3 3,708 02-24-2018, 12:54 PM
Last Post: Luke
  Android Regular images are Android TV images Nurza 8 9,816 01-10-2018, 04:57 PM
Last Post: richzhai
