[Archived] ANNOUNCING RECALBOX FOR THE ROCK64 - ALPHA RELEASE
(04-30-2018, 09:42 AM)S3phi40T Wrote: How do I do that?
Wysłane z mojego Redmi Note 4 przy użyciu Tapatalka
Mount eMMC -> BOOT -> extlinux -> extlinux.conf
in the conf set change mmcblk0p2 for mmcblk1p2
Booted up.
Could be automated somehow Smile
Thank you very much for your work, I am downloading the image and later I will try it again. Thanks again for your time to support the rock64
No original Xbox One controller support?
After switching storage to disk - it sees only files crested "itself", doesn't see the rest of disk - fortunately it didn't format it.
I wanted to combine it with with SMB and NFS shares so I'm playing with smb.comf
I have already discovered SSH default access:
root/recalboxroot
As I want to use disk only as media/roms source not mounting points, it looks I'll have to play a bit to achieve proper SMB and NFS support Big Grin
@Mrfixit2001
Can NFS support be added?
Xbox One Kodi client doesn't support SMB shares.
My main goal is to use Emulators + SMB + NFS
(04-30-2018, 11:45 AM)S3phi40T Wrote: @Mrfixit2001
Can it ? yes. Will it - no. The reason is, once we've got the code cleaned up it'll be passed onto Recalbox to maintain, and Recalbox only has the bits it has ... NFS is not one of them.
Sad it seems I'll get back to Ayufan's releases then.
...but I'm thinking of dualboot - Recalbox on mSD and Ayufan's builld on eMMC.
Anyways, as a pure retro emulator, Recalbox seems to be nice distribution for EmulationStation.
(04-30-2018, 12:25 PM)S3phi40T Wrote: Sad it seems I'll get back to Ayufan's releases then.
Hold your horses ... I may have been wrong about that. Perhaps we could add NFS to it after all. Wait for mrfixit2001 to confirm...
#19
The libraries for nfs could likely be added to the next release, but the users would have to be responsible for the configuration, since nothing in the build actually requires it. So sure, I'll have the config include libnfs for the next image and hopefully that will meet the need! Smile
#20
Thanks for your hard work!
The two USB wifi adapters I had on hand didn't work. They show up on dmesg but their LEDs didn't light up. I'll have to grab the one from the Rock64 store I suppose. Everything else works great so far, however!
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 151 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,361 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 335 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 615 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 + Klipper + KlipperScreen Instructions godzilla62 0 609 10-22-2023, 01:52 AM
Last Post: godzilla62
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,384 10-12-2023, 05:14 PM
Last Post: tpaul
  slarm64 (unofficial slackware) Rock64 RK3328 (aarch64) mara 133 190,493 10-09-2023, 03:31 AM
  arch rock64 does not boot nemnob 0 592 07-09-2023, 03:28 AM
Last Post: nemnob
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 651 05-27-2023, 06:11 AM
Last Post: Transportsicherung
  DietPi OS for ROCK64 MichaIng 41 33,361 12-07-2022, 08:22 PM
Last Post: luminosity7
