sd format?for pine 64
how to format the sd card, fat, ntfs, etc.to install the various systems.thanks
(03-30-2018, 01:55 PM)angegardien Wrote: how to format the sd card, fat, ntfs, etc.to install the various systems.thanks
Best option is to use the pine64 installer - it will let you download and write your SD cards in one go. But basically, there is no need to 'format' the sd card prior to use - the image (e.g. one of the ones linked in the green box at the top of every forum page) which you download and write to the SD card completely overwrites anything else on the card, so formatting just adds extra wear and tear.
Hi All, I just bought 2, 16 gig SanDisk SSD mini's and neither of them will load any Pine64 distros. I used both the Pine64 installer and Applepi-Baker and they both error'd out.  Can someone tell me if I am using the wrong chips or what I am doing incorrectly.
Always worked for me in the past.  My current chip got corrupted.
Thanks in Advance,
Brad Hansen
I just formatted fat32 and kept going, but I would do some sort of formatting on micro sd. imo.
  PINE A64 SBC: Clone of a functional 32GB SD card doesn't boot burningkrome 3 1,623 05-19-2023, 07:43 AM
Last Post: crocspot
  PINE A64 Ubuntu 18 or 20 IMG with touchscreen? burningkrome 0 609 04-29-2023, 05:13 AM
Last Post: burningkrome
  Pine A64 does only boot with Android 5.1 Dude 6 3,942 07-03-2022, 02:18 PM
Last Post: Dude
  Pine A64+ vs LCD do not boot DDS 3 5,989 02-23-2021, 05:33 PM
Last Post: thedu
  Autodetect if Pine unit is a Pine A64+ or PineA64-LTS pkfpeters 1 3,343 02-09-2021, 12:17 AM
  Pine 64 | 2GB x2 & Acrylic Cases x2 for Sale | Canada - GTA ViperVi 1 4,507 01-18-2021, 03:45 PM
Last Post: squidius
  Node Red on the Pine DonFL 0 2,776 12-16-2019, 04:21 PM
Last Post: DonFL
Photo Pine A64+ from Kick starter running Pi-Hole netHolio 0 3,248 12-02-2019, 09:36 PM
Last Post: netHolio
  NetBSD for Pine A64(+) Luke 3 6,739 10-05-2019, 11:04 PM
Last Post: mrgtwentythree
  Can anyone run Boinc on Pine models? MarijusR 6 9,719 09-11-2019, 06:41 AM
Last Post: letarg
