03-30-2018, 01:55 PM
how to format the sd card, fat, ntfs, etc.to install the various systems.thanks
sd format?for pine 64
03-31-2018, 03:49 AM
(03-30-2018, 01:55 PM)angegardien Wrote: how to format the sd card, fat, ntfs, etc.to install the various systems.thanks Best option is to use the pine64 installer - it will let you download and write your SD cards in one go. But basically, there is no need to 'format' the sd card prior to use - the image (e.g. one of the ones linked in the green box at the top of every forum page) which you download and write to the SD card completely overwrites anything else on the card, so formatting just adds extra wear and tear.
04-12-2018, 12:47 PM
(03-31-2018, 03:49 AM)pfeerick Wrote:(03-30-2018, 01:55 PM)angegardien Wrote: how to format the sd card, fat, ntfs, etc.to install the various systems.thanks Hi All, I just bought 2, 16 gig SanDisk SSD mini's and neither of them will load any Pine64 distros. I used both the Pine64 installer and Applepi-Baker and they both error'd out. Can someone tell me if I am using the wrong chips or what I am doing incorrectly. Always worked for me in the past. My current chip got corrupted. Thanks in Advance, Brad Hansen
12-06-2020, 03:53 PM
Pine A64 does only boot with Android 5.1 | Dude | 6 | 2,035 |
07-03-2022, 02:18 PM Last Post: Dude |
Pine A64+ vs LCD do not boot | DDS | 3 | 4,658 |
02-23-2021, 05:33 PM Last Post: thedu |
Autodetect if Pine unit is a Pine A64+ or PineA64-LTS | pkfpeters | 1 | 2,395 |
02-09-2021, 12:17 AM Last Post: tllim |
Pine 64 | 2GB x2 & Acrylic Cases x2 for Sale | Canada - GTA | ViperVi | 1 | 3,657 |
01-18-2021, 03:45 PM Last Post: squidius |
Node Red on the Pine | DonFL | 0 | 2,301 |
12-16-2019, 04:21 PM Last Post: DonFL |
Pine A64+ from Kick starter running Pi-Hole | netHolio | 0 | 2,683 |
12-02-2019, 09:36 PM Last Post: netHolio |
NetBSD for Pine A64(+) | Luke | 3 | 5,583 |
10-05-2019, 11:04 PM Last Post: mrgtwentythree |
Can anyone run Boinc on Pine models? | MarijusR | 6 | 7,768 |
09-11-2019, 06:41 AM Last Post: letarg |
There is a usable distro for Pine A64? | polv89 | 6 | 8,850 |
06-09-2019, 03:32 PM Last Post: dkebler |
Pine A64 stuck in boot process | joey | 1 | 2,830 |
05-28-2019, 09:07 PM Last Post: joey |
